Whoosh RMM is shot
pixelzombie
It just didn't feel right when shifting or accelerating, and I'm glad it wasn't clutch related.
I'll have to order a new bushing, but is it safe to drive like this? The OEM is still in my garage.
Also, is it possible the the mount is probably damaged after a week of driving on it?
XR650R
You can determine that when you take it out.
I drove like that for a bit, the mount seemed fine. My front bushing was completely missing and the rear was damaged. I suspect you'll be fine until the new bushing arrives.
I may need to take a look at mine. I've been getting a clunk on aggressive WOT 1-2 shifts.
Time for an AWR* 70 Durometer
pixelzombie
pixelzombie
It felt off, but I couldn't tell if it was a clutch issue. It is definitely noticeable in city driving or when accelerating in the low gears as the heavy clunk does not sound normal. Mine started acting just after I put in a new IC, so I thought I had messed something up.
pixelzombie
pixelzombie
Its amazing how quiet the car runs now with the new bushings. I literally thought I had an exhaust issue with the way it sounded while accelerating. The old one was dry as stale bread, I wonder how long they last in desert conditions. Also, there's very little sign of damage to the main part of the mount. I was worried that it was damaged with the pounding noise it was making.
How long did that original bushing last? Just curious.
Also, it appears that they're using a different material for their new replacement bushings, which will hopefully last a bit longer.
I need a RMM for my newly acquired ST, but I haven't decided which one to get yet.
I would have said this until mine just exploded, going awr this time.
fair point. ultimately, there are a lot of options on the aftermarket, and killer is welcome to try any one he wants. i wish i could get vt, but i already have a whoosh that came on the car. i'm of the mindset "if it ain't broken, don't fix it" (most of the time, but this isn't entirely by choice)
