Aftermarket radiator Temperatures
Noosa, Queensland, Australia
Hi everyone, I replaced the stock radiator with a Mishimoto. At time I still see high temp like 97c was today the max i saw.
Just wanring to hear from anyone who replaced the radiator even with anorher brand, what's your temperatured going from to? Also i have a Mishimoto thermostat installed.
Cheers
Fab
Irvine, CA
206F is not high at all, it is normal. Before an aftermarket radiator I would see nearly 110C before I would turn the heater on.
I have a Koyo radiator with 180 degree thermostat, I see 90-95C every day and have no concerns with the system handling that pressure. 105+ is where concerns begin.
Grsemky
U.S. Navy Veteran
Arizona
Cheers
Fab
What model year? They switched to a cooler thermostat in '16, if you're concerned you can try swapping it out
Can confirm 90-95 all day in the AZ desert, this was grabbed post freeway rip...
Slightly [offtopic], but did the Koyorad drop right in like the factory unit, with NO bumper cover gaps/problems, or AC condenser fitment troubles?
Irvine, CA
Cosmetics have never been a concern of mine. The bumper cover has always had gaps since installing v3 ic, but the radiator dropped in place of the factory garbage without any issues that I noticed.
Manufacturers intentionally run modern engines hotter for it reduces emissions and carbon on the piston heads and valves. (notice the higher fan activation temps) Nothing to worry about.
If you're tracking it, your priorities will be different. Lower intake temps net noticeable performance gains.
Capri to ST
CHAPEL HILL, NC, USA
This is something that should get more attention. People automatically think lower is better, and that's not always the case. They also sometimes think a temperature is too high when it's not.
