Mr. Spam's Street and SCCA Autocross build (modified)
Kansas City, MO, USA
2014 1.6L Fiesta ST Mod List
Block/Engine
New short block – Panda built stage 2 Fiesta ST Short Block with parts from Panda Motorworks to complete build, including
-Supertech Beehive Valve Spring Kit
-Supertech Ford Ecoboost 1.6L Black Nitrided Intake Valve x 8
-Supertech Ford Ecoboost 1.6L Sodium Filled Inconel Exhaust Valve x 8
-Supertech 5 mm Single Groove Valve Lock Conversion – set of 32
Mountune 1.6L Ecoboost Oil Control System Fiesta ST
Mountune Triple Pass radiator upgrade for Fiesta ST
SVT Design vacuum pump delete
Air/Turbo/Exhaust
Injen SP Short Ram Cold Air Intake System (Polished or Wrinkle Black depending on mood) – SP9016(P or WB)
Garrett GTX 2867R Gen II turbo with A/R 0.64
Bravo Alpha Performance BIG Fiesta ST Intercooler Kit
2014+ Fiseta ST Whoosh brand Intercooler Boost Hose kit
WOR Fabrications Fiesta ST Hot Parts Kit: Manifold, Downpipe, Wastegate Dump Tube, 2.5 Hotside Charge Pipe, Oil Return Line
New Ford OEM manifold gasket and DP-Exhaust gasket
ATP Fiesta ST Oil feed and coolant line set (ATP-FIE-022)
Turbosmart WG40 Gen V Comp-Gate 40mm – 14 psi Black
ATP Tial Housing, Turbine, Stainless, GTX28, 0.64 A/R V-band inlet/outlet
Tial Stainless V-band Clamp Turbine (Downpipe side) Outlet for Housing GT28
Tial Stainless V-band Clamp Turbine (Manifold side) Inlet for Housing GT28
Thermal R&D 3” Fiesta ST Exhaust system
VelossaTech BigMouth 2014-2019 Ford Fiesta ST Ram Air Intake Snorkel
SVT Design Fresh Air Duct for 2014-2019 Fiesta ST Cold Air Intake
SVT Design Ignition coil tray and hold-down kit with BOSCH 0221604700 Focus ST Ignition Coils x4
Fuel
Boomba Ford 1.6L Fiesta ST Aux Fuel Rail
Bosch EV14 Universal 48 mm standard 550cc/min injectors x 4
Electronics
Cobb Ford Fiesta ST Accessport V3
Split Second AIC1-AH4 Absolute Pressure, 4Hi Z Additional Injector Controller
Braille G20S Lithium Ion Battery in MeLe Fiesta ST Battery mount
52 mm Fiesta ST Boost Gauge Pod Vent Holder Mount
Sync 1 to Sync 3 upgrade from 4D Tech
Drivetrain
Wavetrac LSD
ATB Differential Installation kit (Mountune)
SPEC Stage 3 Clutch
SPEC Aluminum flywheel
Chassis/Suspension
BC Racing BR series Coilovers (front) and Springs/Shocks (rear)
TB Performance Trunk Brace for Ford Fiesta ST
TB Performance Crossmember Brace for Ford Fiesta ST
TB Performance Front Crash Bar for Ford Fiesta ST
Exterior
Ford Fiesta DEPO headlights R/L 431-11B5RMLD-EM and 431-11B5LMLD-EM
ZDEERAOTO Smoked LED 3rd Third Brake Light Ford Fiesta - Roof Center High Mount
GLISTUNING LED Tail Lights Assembly - Ford Fiesta 2011-2019
S
Thread Starter #2
I've got The EBC Racing Apollo-4 front big brake kit on order from Whoosh. I've also got the rear brake caliper bracket kit and 280 mm rotors with EBC pads from Whoosh, already arrived. Will do the complete brake upgrade when the fronts show up in a few weeks.
My rear calipers look like #@*&, so I ordered the G2 High Temperature Brake Caliper Paint System (red) for them. Just for kicks (since they are the OEM calipers) I went ahead and ordered "Ford" brake calipers decals for the years. I figure the fronts will have "EBC" on them, so will be fun to see if people notice that they don't match...
S
SVT design vacuum pump delete pics. There's a bit more room in the engine bay between the G20S battery and the vacuum pump delete. Parts on the floor are what was removed - vacuum pump and one hose/ check valve. The check valve was replaced, so not technically completely removed, more like replaced.
Grsemky
U.S. Navy Veteran
Arizona
Block/Engine
Air/Turbo/Exhaust
Fuel
Electronics
Drivetrain
Wavetrac LSD
SPEC Stage 3 Clutch
Chassis/Suspension
Exterior
Unless you're doing it for looks the big mouth will not be doing much, its designed for stock style air boxes not open filters
S
It should still get a bit cooler air in the vicinity of the intake. Granted, there will not be any ram effect. I like how it looks as well.
S
Why would you delete the vacuum pump? It has a purpose.
You raise a good point. The vacuum pump delete is not without controversy. People have been doing it with the FoST/FoRS platforms for several years.
As you know, traditionally non-boosted cars generate vacuum from the intake manifold. A boosted vehicle theoretically needs a vacuum pump to generate vacuum at times.
In reality, between the vacuum reservoir and the non-boosted engine time, you should really never run out of vacuum. Think about it - how often are you running the engine in a boosted state while at the same time applying the brakes?
Pros and cons of the vacuum pump delete:
Pro:
  • Reliability: Eliminates a known failure point that can lock up camshafts (rare but severe) or fail, starving the brake booster of vacuum.
  • Efficiency: Reduces parasitic load on the camshaft for a tiny performance/efficiency gain.
  • Cleanliness: Creates a much cleaner, less cluttered look in the engine bay.
  • Vacuum Source: Provides a clean port for boost gauges, blow-off valves, or other vacuum-referenced components.
Con:
Oil Leaks: The most common issue is oil leaking from the delete plate, often from bad, missing, or improperly seated O-rings/gaskets, sometimes requiring RTV sealant.
Brake Vacuum Loss: If the brake booster's vacuum source isn't properly tapped into another port (like the PCV system), you lose power assist for your brakes, making them hard to press.
Incorrect Rerouting: Improperly plugging ports or rerouting the PCV can cause other issues, but some users successfully use a catch can's third port for vacuum.
Parasitic Loss & Engine Strain: The pump robs power; deleting it reduces engine load, but the pump itself is there to provide consistent vacuum for the brake booster and potentially control cam timing, so removing it shifts the burden.
Misguided Mod: Many argue it's unnecessary and risky, as a failed OEM pump can cause major engine issues (like cam lock-up), but deleting it creates new failure points (leaks).
I decided, at the end of the day, to give it a try. It's not a problem to reinstall the vacuum pump should I ever want to revert to that. Have I noticed a difference?
In fact I think I'm getting a stronger vacuum from the engine than I did from the pump. Brake response seems a bit more crisp.
So, great question! I hope my answer is satisfactory!
Italy
Your build is insane, i love it.
I have one question about the vacuum pump delete. I wasn't even aware that such thing existed. But i've now red a bunch of forums. Afaik is there to provide vacuum mostly for the brake booster circuit during periods of either Zero pressure (turbo at 0 bar) or positive pressure. Is it known to leak on the Fiesta ST? On my MiTo now i, apparently, have it as well.
S
....Is it known to leak on the Fiesta ST? On my MiTo now i, apparently, have it as well.
I used gasket sealer on the delete plate, no leaking so far. I also used hose clamps (probably overkill) on all the hose connections in the delete harness.
I've not had any leaking. I'm not aware of what other folks' experiences might be, as I actually don't know of anyone else who has done this! I'm sure there are folks who have.
I don't even think about it any more- it's just not a factor when I drive.
S
I've already posted this over in the "What did I do today..." section so if you've seen this there then no need to read further.
Installed the 4" SVT Design Fab Intake about 2 weeks ago. Getting it to fit right has been a bit fidgety. Had to buy a short extension of 3" silicone hose as well as a coupler. The basic issue is that I've got the WOR Fab exhaust manifold and the "L" silicone pipe Adam provided didn't go far enough lateral. See the diagram below.
There are several benefits, now that I've got everything cinched down. It's a really BF intake, as you can see from the pictures. I can't say that I notice any "butt dyno" difference, but the new noises are fun. The first picture is the Injen intake that I took out - the next picture is the SVT intake - you can appreciate the size. The other benefit is that (and you can see the difference between the Injen and the SVT intake) the recirc harness inserts from below into the intake just behind the filter. One of the pics is a close up showing the MAF (ok, temp) sensor and the insertion of the recirc harness in close proximity.
The last picture shows the new gel badge in situ on the engine cover for Cneu. Appreciate the comments!
FL
Quick question , No heat shield for the intake ? Awesome build !
S
Thanks! It's got the shiny tape on it...we will see how it holds up! :D I did replace the gold shiny tape with silver shiny tape, so it looks more cohesive. Gotta love Amazon.
FIREWESS Aluminum Foil Heat Shield Tape 2inx66ft, Silver Heat ReflectiveTape, Fiberglass High Temp Tape for Exhaust, for Hose and Auto Use
https://a.co/d/0hxMmg0n
Burlington, NC, USA
That’s my only gripe with the tubular manifolds. I very much want a heat shield for track days. My Cobb carbon intake got cooked pretty good before I took both it and the tubular mani off. Also it melted the wire loom on my firewall.
S
Thread Starter #20
I am dropping the transmission and sending it off to Clarke Transmissions. Hopefully it will be salvageable. Did this at a recent Des Moines AutoX event. I suspect that this happened because I was basically using stock motor mounts. I did have the Cobb RMM, but I think the engine flexed too much and damaged itself during a particularly hard spin-out. So motor mount upgrade is definitely in order. I'm going with the Damon full motor mount set.
