Does nobody respond on this forum anymore ?
Ryry01
England
Tuner has fobbed me off blaming the car !
cheers for replies guys.
Tuning should be relatively similar surely ?
From my knowledge the wastegate duty cycle is off hence the low boost issue.
mods are
larger front mount intercooler.
hard pipe/silicone hose boost pipe kit.
99 ron fuel.
smaller/lightweight water pump pulley.
solid cross over pipe.
silicone hose/induction kit ram air.
larger turbo elbow.
turbosmart 7psi turbo actuator.
one step colder spark plugs gapped to 0.028".
decat.
Mishimoto lower temp stat.
timing belt/waterpump replaced by myself so that rules out a timing issue.
vacuum test with zero leaks.
3inch cat back exhaust.
Smoke test passed.
compression good.
no faults.
doesnt use oil or coolant.
Could someone provide me some datalog pictures of their cars running around 1.55bar of boost please so i can compare.
if you could post me these parameters up as in the picture that would be great cheers.
Atlanta
since you have the aftermarket WGA, need to ensure the preload setting is within spec, otherwise it can cause all sort of boost control issues. They dont come pre-set.
Ryry01
England
The company who tuned my car blamed it on the turbosmart actuator and said their flash tune is designed to work with the stock one so i fitted a new oem actuator and spent the day logging and adjusting the preload and it made no difference to the data logs apart from right at the beginning of the rev range and made the car pick up quicker, i went from 3 turns of preload to 5,7,9,full and then only one turn (car felt terrible low down at 1 turn preload)
other tuners who have seen my datalogs said straight away its the wastegate duty cycle and thats set via the flash/tune.
My friend has what we class as a stage 2 tune so same mods (different branded parts and tuner) and his makes 1.55 bar of boost. Our datalogs are pretty much identical apart from the wgdc, his is much higher iirc 78% which make sense from my knowledge since if mine is lower its bleeding boost rather than pressurising the motor. Unless thats not how it works.
thanks for the reply.
Atlanta
so, since you went back to the stock WGA, did you go back to the OEM-like tune to compare drivability/performance? Over here, the Cobb AP has a default tune that is similar to stock. As you are decatted, with prob throw error codes, but might be enough to quickly rule out issues with the WGA and boost control solenoid? Since you are using a different engine mgmt system, some speculation there on my part.
The hose routing on the boost solenoid is correct? Were any of those inadvertently changed when replacing the WGA? that can also cause very odd boost behaviors. Just something to validate if you havent already.
It is throwing off any fault codes that could help point you in a direction? I expect they would be different than our, but still something to check.
Is there another tuner over there that you can engage to diagnose?
Ryry01
England
I have no way of flashing my own tunes, it was the tuners who flashed the car (very well known over here in the UK).
Its had a new Pierburg boost solenoid and the 3 vacuum lines are in the right place, surely having them mixed up would throw a fault code no ?
car has zero fault codes.
Ryry01
England
You should probably just take it to STealthworx and have them map it properly
I will be going elsewhere but i also want to get to the bottom of this and understand more myself if that makes sense ? I have years of experience with cars just not so much on the tuning side of things.
Cheers
Ryry01
England
Another place you could try asking is the Ford Fiesta MK7 Track Car Projects page on Facebook. It's UK centric and I see frequent posts and comments from some of the well known tuners.
Thanks for the reply.
You'd think people on the Fiesta st forum would know a thing or 2, hence why i posted on here ? no ?
