Help with Glowshift boost gauge install...
ST_Bo
York, Pa
I have a 2018 fiesta st I'm trying to install a glowshift boost gauge I just don't no where to connect everything for the constant power I had it fuse tapped into the horn for ignition source I had it fused tapped into the radio for ground I connected it to the ground in the headlight switch and headlight source I had it plugged into a purple an white wire of the headlight switch I think the ground or headlight source switch is where I'm having the problem I'm clueless with cars but I love my fiesta and I want to do everything my self with this car and learn along the way any help would be appreciated
Portland
Did you get this figured out? If not, I will crawl around under my dashboard and see if I can remember which wires I ran where, since the interior is currently stripped out of my car and this would be fairly easy.
ST_Bo
York, Pa
No I still didn't get it figured out the only way I got it to work is running all 3 wires straight to the battery with a fuse I tried multiple fuses for the ignition wire and can not get it figured out
Clyde
I recently installed a GlowShift oil pressure/temperature gauge. I tapped into power in the glovebox area fuse box. I used fuse taps to hook the constant up into the brake light fuse (10amp) and used the wiper fuse (20amp) for the ignition source. Seems to work fine so far. Also, note that the left side is the "feed" side and the right is the load side, so with the piggyback style fuse taps, you'll want the wire leading off to the right. For the ground I hooked it up to an existing ground at the bottom of the drivers side kick panel, that's right below the OBD2 port and hood pop, down by the floor. I didn't bother hooking up the dimmer wire to a headlight source, full bright all the time is fine for me.
ST_Bo
ST_Bo
York, Pa
I'll have to try it when I'm off work again but I had my constant hooked up to the horn fuse in the main fuse box under the hood and hooked the ignition source wire the the wipers also and nothing no power I moved the ignition wire to the radio fuse also and still nothing but I'll hook it up the same way you do and see what happens thank you
Clyde
This was the first configuration I tried, so I must have just had a lucky guess.
ST_Bo
ST_Bo
York, Pa
I was thinking maybe the gauge is messed up I just got an auto meter gauge to hook up also so if that one works and the glowshift doesn't then I no it's something with the gauge thank you for the help
