DIYer Timing Belt
I thought I would put in my issues / things changing the timing belt for anybody who is considering doing it themselves - I am by no means a mechanic but I have been working on my own cars now doing most mechanical work for the last 5 years so I have a somewhat general idea of how to do things. I hit 10 years and 150k miles so the belt was needing to be done -overall the condition of the belt was fine but still I would prefer to avoid any issues -
The good:
- It wasn't nearly as complicated as some of the other posts have made it sound - I definitely took my time and wasn't in any rush to get the car back on the road -
- I didn't have any issues removing anything or putting anything back on -
- After I put everything back on I didn't have any codes
Insights:
- You do have to remove the passenger CV axle in order to access the timing bolt on the side of the block - It wasn't so much a deal for me since I was planning on changing the axle seals anyway since mine were leaking -
- I would highly recommend getting the flywheel locking tool - from my understanding these are interference engines and I wouldn't want to mess around with the crank moving at all and causing catastrophic head and piston damage -
- Highly recommend changing your water pump and timing belt tensioner while you are in there as well -
- I cleaned my intake valves while I had the manifold off, they weren't too bad but I did notice that I had less stuttering at WOT after doing it -
- The torque on the crankshaft bolt was intense but not as bad as some people made it out to be - I had the car pretty high up on my 6 ton jack stands so I was able to get a cheater bar in for the last 90 and 15 degree adjustments.
The bad:
- I would plan on the harmonic balancer being stuck on there - I had to modify a 2 arm puller since there is pretty limited room to get a 3 arm puller in there -
Hope this helps anybody else looking to safe 1000$K which is what I was quoted from my local shop.
Cheers
P
For $1k I’d have someone else do it all day. I got quoted $2700 for water pump, oil pump, timing belt.
Yeah of course if I had the money to pay someone then I would have happily had someone else, but money is tight.
Just to add some details, my timing belt by a dealership was about $1500 installed. This is in Oregon.
rallytaff
I paid around $2,200 to have mine done. My mechanic has spent over 20 yrs building Ford engines and it runs like new!
Hey Pbeatty thank you for the good write up and giving me a little more confidence to try this myself! I just have a couple questions for you before I bite the bullet:
How high are we talking that you lifted the car up? I only have some 2 ton jack stands and a small jack, I'm not sure I can get it too high with those.
Also, what is your technique for lifting in order to get the car up on 4 stands? I've only ever done front up or rear up for the work I've done so far.
And cleaning the intake valves, what did you use for that? Is there a special cleaner to use or any caution I need to take?
Going to be replacing the axle seals as well as I think I got a pretty bad leak too!
Thank you in advance!
P
Sorry for the delayed reponse. Glad that it has helped a bit -
I mean I raised it as high as my max 3ton jack stands would go then I swapped in my 6 ton stands. Having the 3 ton stands up that high make me feel a bit nervous. You could build 2x4 wood stands for the wheels and then just have the front passenger supported by a stand as high as you could go and I feel that this would be very safe.
I lifted the car in the front from the subframe on both sides and incrementally adjusted the stands as I felt it was safer. If you have a long reach jack it could easily get to the subframe from the front or side and lift the whole front of the car.
For intake valve cleaning I just used carb cleaner and some nylon brushes from harbor freight and I put a silicone glob over the tip so it would scratch the aluminum at all. I cut off the handle of the brushes after I had done the best I could manually and then used my drill to give them another one over. Just make sure the valve is 100% closed before spraying the cleaner. If you spray some cleaner in and it just dissapears then the valve is not closed or sealed and all the cleaner will get into the head potentially the oil.
I also did some gasket silicone on my axle seals because I'm sick and tired of them leaking.
Hope this helps
