Switchback's Cursed Fiesta Log
EscortSportage
U.S. Marine Veteran
NY
#41
Ah, my bad. Coolant piping you’re good, it’s the cold side charge pipe from intercooler to throttle body that won’t fit with a bigger radiator.
Ill have to trim the plastic around the cooling fan, I was looking at this yesterday since you mentioned it. Seems like the fan assembly will be the issue.
S
San Diego
Thread Starter #42
It’s been a minute since I last posted here, but work continues! I recently installed the Pierce Motorsports tow hook kit, but made a bit of a change to the design.
As you who have installed this kit know, you have to *somehow* get a pair of bolts and washers inside the crash bar to hold the bracket in place. Instead of doing that (and hating life) I used a rivnut tool we have been using on the Lemons project. It worked perfectly and from my research is as strong (if not stronger) than the original washer and nut setup Pierce includes with the kit.
While I was in there, I also replaced the center bumper support as it was broken. The bumper no longer sags as much! The original piece is held in there with hot glue so after the tedious process of peeling it off I got some new hot glue (the industrial heavy duty stuff) and glued on the new bracket.
EDIT: apparently mobile safari doesn't like to embed images properly. I'll fix it tonight when I'm home from work.
S
San Diego
Thread Starter #43
My bad luck just keeps on coming. While swapping out the turbo for a slightly used one and installing new exhaust manifold studs, I found that one of the previous owners snapped one of the exhaust manifold studs (far passenger side). This is very possibly why I was having low boost, if the exhaust manifold was leaking/warped.
I'm seriously starting to wonder if I should just rid myself of this Fiesta and go get something else.
Fusion Works
Huntsville, AL, USA
#44
Plug the port and weld a nut to the end of that stud, then back it out and move on with the car. It will be a bit of a pain, but beats pulling the engine.
S
San Diego
Thread Starter #45
Honestly my comment is more about everything that's continued to happen to the fiesta since I bought it. Exhaust, Timing, Brakes, Tires, Transmission (4 grand for 2x slave cylinder replacements), and now the exhaust manifold stud that's likely the cause of my boost leak. Just saying I've had really bad luck with this fiesta.
S
San Diego
Thread Starter #46
Well after a weekend of swearing, yelling at the sun (and sweating) a friend and I were able to pull the stud out. Welding was a bust, harbor freight reverse drill bit worked and I've replaced the studs with ARP studs from whoosh. I really want to encase this bit of stud in resin as a victory trophy.
The Fiesta has been reassembled with a used turbo, time to see if I'm making any more power and if the car is stable and healthy again. I will say the test drive I did while the Scroth belts were installed made me feel very racecar.
S
San Diego
Thread Starter #47
Well, my incredibly bad luck with my Fiesta continues.
Took the car out for a trial run and some canyon blasting, and after about 20 minutes of sustained driving I got a nice assortment of codes:
P0300 - Random/multiple misfire
P0301 - Cylinder 1 Misfire
P0304 - Cylinder 4 Misfire
Cleared the codes and continued driving (to see if it was a one-off) and P0304 came back within 5 minutes of driving. Cleared them again and aborted my drive and drove home (on the highway, cruising) without any new codes. I recently re-loaded my Dizzy stage 2 tune, which seemed fine for daily driving (even smashing the pedal when getting on the highway etc). I had planned on doing a time attack on Tuesday but that is probably not going to happen.
I recently (less than 2k miles ago) replaced the spark plugs with NGK Ruthenium HX gapped to .028 so I certainly hope it's not a plug issue, but at this point I'm sort of over the constant problems.
S
San Diego
Thread Starter #48
Well I tried to pull the spark plugs, turns out the mechanic who I initially had them check for boost issues overtorqued the coil packs and now the bolt is rotating freely so I can't pull Cylinder 1s coil pack and sparkplug out.
I'm fed up with dumping tons of money into this car, I'm selling it. Guess coming back to a Fiesta was the wrong move overall.
S
San Diego
Thread Starter #50
Yeah, this is the worst part of this car is it seems to be a never-ending pit of despair. The operating cost per mile is double what the Corvette is, just due to all the deferred maintenance that I've had to complete.
On the good-ish news side, we took the whole coilpack mounting bracket off (I was previously unaware that the Coilpack mounting bracket and the valve cover gasket were the same piece, which is (luckily) not the case. We popped it off, and (redneck engineering) used a rivnut to replace the heat set insert. I'll hammer on it next weekend and try to see if it misfires and if it does, does it return on the same cylinder or if it moves. Current consensus is the car was getting hot (30 minutes of backroads in Cali inland summer) and the coil packs are iffy at high temps/high load.
The thing that really peeves me is that when the car is driving well it's such a blast to drive. Yeah it doesn't have the power or planted feeling of my Corvette but it just darts in and has such a lively feeling, just with how lightweight it is. One of the Discord groups I'm in even mentioned how different it is owning a C8 and a FiST, but I think they are extremely complementary. The 30 minutes before the misfiring was really great fun, and temps looked great with the Mountune radiator and Whoosh v3 Intercooler, even with the temps in the high 70s ambient. I truly think the Fiesta would/will be a great track car with how different it is (C8 can just power through bad track placement), I just need to build back up my confidence to make sure it's good for a track event.
S
San Diego
Thread Starter #51
Moved the coil packs around and sent it, sadly the misfires are still present. Tried a base tune as well to knock out a bad tune, which unfortunately didn't help either. Next step is do a compression test to see if I have a messed up motor. Did some datalogs after installing the new turbo and I'm still stuck at 180ish horsepower, which is low for a Cobb Stage 2 or Dizzy Stage 2 tune even on 91oct. The RPMs tend to fluctuate at higher revs as well.
For reference, when initially installing the dizzy tune I swapped in some new NGK Ruthenium plugs, gapped to .028, So I'm already one step colder on plugs.
Edit: sat in the car and revved it, once the car gets to 3k RPM if I hold it there it starts misfiring like crazy, and eventually throws P0300, P0301, P0304 and P0316. The weird part is P0316 is supposed to be a “first 1000 revolutions” code but it’s triggering after the cars been running at idle for a few minutes.
S
San Diego
Thread Starter #52
So good thing is my block appears to be healthy. Did a compression test and my results looked good, thank you Fiesta gods (If you exist. Also if you exist why did you give me a cursed FiST?)
Cyl1: 170psi
Cyl2: 172psi
Cyl3: 174psi
Cyl4: 172psi
I also moved injectors on Cylinder 1 and 2 to see if it followed the injector, sadly still misfire codes on 1 and 4. I also swapped in my warmer OE FoMoCo spark plugs to see if I had a set of bad plugs, which did not help any.
So at this point I've checked off Spark and fuel, last thing is air. Since the car has 123k miles it could have gummed up intake valves, which I'm not going to mess with getting the intake manifold off. So I'm going to send it to the shop to see if they can figure out what in the hell is going on, hopefully it's just gunked up intake valves that need a good walnut blasting.
I've got until October 2nd/October 4th to get my Fiesta back running well, that's when my first track day is scheduled (Chuckwalla or Buttonwillow Circuit, still debating which track I want to try next) and I would really like to get the Fiesta fully healthy again.
Between misfire codes I was keeping up with my Buddy in his Porsche GT4 charging up Palomar Mountain, it was a blast even when having to pull over every once in a while to reset codes.
S
San Diego
Thread Starter #53
Alright. Well, probably one of the last posts I'll make for a bit.
The Fiesta is no longer going to hit the track, I'm just going to keep running it as a daily for getting to/from work. I realized that to make the FiST track-ready I'd need quite a few relatively expensive items like new suspension (current suspension is a bit bouncy on rougher roads), an LSD, and a brake kit. Adding all that up brings me to a cost that I'd rather put into my newer-and-faster Corvette. So I'm likely selling my Schroth Quickfit pro kit and the brake ducts as they won't be needed for Street/Canyon use.
Also considering my quantity of problems this is now officially the "Switchback's cursed fiesta log" to track how many headaches I've had with this damned thing. Might still get sold, who knows.
none
#54
Aww the old girl is going to be put on pasture. Can't deny they are good dailies, easy to park and get around town with. And can follow traffic and get decent mileage.
S
San Diego
Thread Starter #56
Photos of, and details on, the vette please. 👍
Sure! It's a 2022 C8 Z51 (3LT if that matters) with Magride and the front lift in white. The previous owner made a few choice alibaba mods (front splitter, side ground effects, duckbill spoiler attachements) which I've actually grown to like a bit. The side bits help keep OPR off the side of the car when tracking it, and I think adds a bit more black accenting that I like.
This photo is from a March 28th track day up at Buttonwillow, on stock tires/pads/rotors. Only change I made was putting in Castrol SRF to make sure I didn't boil the brake fluid given the Electronic Brake Booster system. Tires got greasy, pads and rotors overheated but overall the car performed wonderfully in stock form. I was also running a stock alignment (Not the Chevrolet recommended track alignment) so I was pretty understeer-y through the track. Still, absolutely fantastic car and even stock powertrain wise it pulls like an absolute truck.
Since that track day I've picked up new to me Apex wheels for the track, wrapped in 2 track-day old Goodyear F1 Supercar 3R 100TW gumballs. The wheels are the biggest positive as these tires probably have 1-2 days left in them. Once temperatures cool down a bit I plan to head back out to Buttonwillow to see how much difference there is with a track alignment and wider tires. (front going from 245 to 275 and rear going from 305 to 325)
