Wheel Bearing - Assembly
I need a new wheel bearing and was going to just get an entire assembly. Looks like you can’t get an assembly for the ST:/.
Anyone have recommendations on tools to remove and install new bearing? Also for purchasing new bearings? I’m in the US. Also please correct me if I can buy an entire assembly.
Please and Thank you Much appreciated
The full assemblies are out of stock at rock auto but you can buy a kit for cheap for front or rear, check the year but I assume parts are the same 2014-2019.
https://www.rockauto.com/en/catalog...81,brake+&+wheel+hub,wheel+bearing+&+hub,1636
pay a local shop to press in the new bearings, ~50 bucks usually depending on where you live. Install is with typical handtools. Obviously I’m oversimplifying, but there are many YouTube videos you could look up too.
J
Thanks dude. I got new bearings and wheel hubs for both front. Also got an Ebc yellow stuff rotors and pads still less then what a shop would charge just to change the bearings. I bought a slap hammer kit and press kit and going to do it myself.
