Will ST front calipers, rotors, front springs, rear shocks, rear springs fit none ST Fiesta?
Carson City
Since I have coilovers and a custom 11.75 BBK on the way I no longer need the these parts. I already shipped off the front struts to a member so just have f/r springs and rear shocks.
The front rotors are already drilled for 4x100 so I will see if a member here that is going to do that mod wants them first.
What would be the best forum to advertise these parts as well?
Rick
R
Carson City
Thanks, I will do that but I was also thinking of a none ST forum as more will see it them there.
U.S. Navy Veteran
SFV, So.Cal.
The front struts, rear shocks, and all springs will interchange.
The front rotors and calipers will not, unless you use an adaptor or change the knuckles as well.
Dave
R
Carson City
Since the Wilwood BBK for the 2011+ regular Fiesta fits our cars it would seem our stock brakes should fit the regular cars....I just thought of it.....maybe it is a wheel issue on stock wheels???
U.S. Navy Veteran
SFV, So.Cal.
I stand corrected.
I was thinking of the rotors and calipers separately.
If you change the rotors and calipers as a set, they will work.
Dave
R
Carson City
This car has eating a fair chunk of change and I am paying for out house and out future home, truck, trailer, etc until the house sells so money is pouring out, selling off what I do not need helps me finish the car:)
Rick
U.S. Navy Veteran
SFV, So.Cal.
15 inch NO, 16 inch fit with 300mm rotors so they should be OK.
The donut spare NO, if you had a front flat, jack the car in the center to lift both ends.
Take the good wheel/tire from the rear and put in front, then put the spare in the rear.
You should do this anyway.
BTW what else you selling?
Dave
R
Carson City
Stock turbo and ported manifold when I get the EFR turbo and different manifold, which might be pretty soon, hope so:)
Spare tire.
Stock springs and rear shocks, all stock sway bar and suspension bushings.
Stock exhaust including DP
Stock radiator but not until I get the 2j-r
Engine cover
Fog lights
Battery
Washer bottle
Floor mats, probably, I have to think it over a bit
Stock speakers, all of them
Intercooler
Front and now maybe rear brakes and drilled rotors(4x100 fronts for sure and maybe rears if I do a rear BBK which I am looking into)
Stock air filter with 293 miles on it
Stock wheel studs
That is all I can think of for now:)
