- Member ID
- #548
- Messages
- 1,086
- Likes
- 120
Hey guys, I just finished a writeup on a Fiesta ST fitted with a set of Eibach front and rear sway bars and snapped a few photos during the install before everything got bolted down so you can actually see the sway bars. Not much in terms of driving impressions yet, but the rear sway bar will definitely help correct the 3-wheeling behavior of the car.
Read the full story HERE
"Stock for stock the Ford Fiesta ST is one of the best handling FWD cars ever made, but thanks to that torsion beam out back, it has a nasty habit of lifting a hind leg more than a dog with a bladder problem when you throw the Fiesta ST aggressively into corners. A little bit of extra love from Eibach helps dial in the Fiesta ST Suspension in the form of an Eibach Front Sway Bar for Fiesta ST and Eibach Rear Sway Bar for Fiesta ST."
Read the full story and see the full photo gallery HERE
If you're interested in a set of Eibach Sway Bars, talk to Jurrian at ModBargains ([email protected]) or call 714-582-3330 (x8002 for Jurrian) consult our friendly, knowledgeable and enthusiastic Mod Experts when considering your next bolt on.
Full disclosure: Chris was already buying the Eibach sway bars, I'm sure you all know what sway bars do, but I reckoned you guys would appreciate seeing the things actually installed on someone's car. I'm not saying Eibach sways are better than any other sway bar, but I can assure you that having an Eibach rear sway bar is definitely better than no rear sway bar at all, and it does help correct (but can't totally eliminate) the 3-wheeling issue.
Cheers,
Nick aka BlueBomber
Cheers,
Nick aka BlueBomber
