Need help! Mountune or Cobb springs? Rubbing with 40 offset?
I need an opinion on which springs I should purchase. I know they are both made by eibach and I am leaning toward the mountune,but they sit a little lower than cobb's and I am wondering if any rubbing may occur. I am running 17x7.5 wheels with a 40 offset.
JPGC
What tires?
You should be fine. I'm running taller tire than that at a 42mm offset and definitely don't come within 2mm of hitting anything anywhere in the suspension stroke.
Nevermind, sorry, I initially missed the part about the wider wheels. Hopefully someone else can chime in.
JPGC
I'm running 17x7.5 with a 42 mm offset with the stock tires 205/40 R17 and I'm not anywhere near close. You should be fine. I have mountune springs, btw.
YIN
I think MR119 is 17x7.....not 17x7.5.....
