Why are the rears a pain in the ass to adjust?  They sound stupid easy to install (looking at them I know why)
So do you think that the shocks with out any bar would actually be...better?  You said it was less fun with the bigger front bar until you put the rears on.
 The rears are a pain to adjust because first, you have to remove them from the car (the easy part), then you have to remove the strut mount and bumpstops, then compress the shock all the way and try to turn it while it's fighting you the whole time.  It's more of a pain than it sounds, believe me. I need to get a beefier vise with soft jaws for sure.
As far as the Konis with no bar...I don't think so, no.  Our cars are SO camber challenged and under sprung up front, so under load our front suspension geometry really compromises our front contact patches.  Additionally, the front is pretty floppy through slaloms....It's SO much better through quick transitions with the front bar.
With the Eibach bar and stock shocks, the car is better through transitions but you have to be careful overloading the front on turn-in and use careful trailbraking.
With the Konis set toward the stiffer end and the Eibach bar up front, the car is just as easy to rotate as stock, MUCH more predictable and precise, easier to drive, incredibly fast through slaloms, and more forgiving.
I have no ego invested in developing a car, I will try anything.  We will add the front Konis Thursday (set soft/faster rebound) and see what that feels like, and then play with them at the next couple events, as they are super easy to adjust with a knob under the hood.  After that, we will likely put the stock bar back on and try cranking up the rebound damping up front and see how that feels.  I will settle on whatever works, not whatever I FEEL SHOULD work.
I really do feel that a larger front bar will be an important aspect of setting this car up, as cranking up the rebound damping (slowing the rebound) helps control the speed of weight transfer/body roll, not total body roll.  If the transitions are fast enough, yes, body roll will be reduced if the suspension is rebounding slower than you are adding lateral transitions, but at the expense of jacking down the suspension.  In a long enough slalom, you could end up jacking it all the way down to the bumpstops, and things would get exciting quickly!
We will see...like I said, I will try every combination.  I just want the car set up as well as I can afford, I don't care about proving any specific theory.  I will report back for sure!
