True though. At least I can comfortably rent the e46 and make money off it. I still haven't let anyone drive my Fiesta except one buddy. Friday I’ll let another buddy who’s a suspension wiz drive it at RA Friday. Only because he’s gonna be setting it up 😂
Decided to try 034 Motorsport’s wind buffeting solution. This is the location they suggest. I’ve tried generic Amazon “lip” stuff in front of the mirror before with no luck. I’ll let y’all know if this works with front windows down and rear windows up. $14 from ECS
Those KE Motorsport Pro T12s look GREAT on that beast!
I can't wait to get mine onto my ride if the night time temps ever get above 50*F around here (new, not heat cycled, 200 tread wear AD09s on them with no garage).
Thank you! I’m very happy with them. They’ve proven to handle curbs without issues and the reduction in weight is noticeable. Definitely cannot go wrong with these wheels. Glad they made them for us!
No tracktime for the Fiesta since my last post. I had a cel P26B7 as soon as I started it that referenced a coolant sensor issue. 2J Racing was kind enough to replace both sensors along with my timing belt and water pump. It was time.. Hopefully she’s good to go for another ten years.
Hey Woods, really appreciate you keeping this thread alive after all these years. I just purchased my old Fiesta I owned about 7 years ago. Found it locally for sale after all this time - so funny.
This time around I'm looking to get out on track a bit! Got some goodies on order - hope to see you around at AMP or RA sometime. Cheers.
A bit of a risk for me since it's my only vehicle now - will probably just stick to the home tracks when I do have time to get out there. I also enjoy doing some trackside photos like some others here, so I may not always be driving. Will hopefully catch a few shots of some members if they happen to be out when I'm around town!
Man Federal RS Pros cannot handle track time. 😂 Had a fun fast first lap then slid two off on the second and even after cooling down they still had no grip. I knew I should’ve swapped the wheels and loaded the car the night before but I was lazy and just drove it to the track as it was. Won’t do that again.
After a lot of time testing these, I think this idea is promising. If they were placed in a different location or a little larger the benefits would be greater. I am buying another set (they're cheap) to test two on both sides. If I can gain access to my buddy's 3D printer I will make a set that's more appropriate for our cars. That may be the best option.. I will update again when I have more to share.
Edit: I was able to lock in some time with my buddy and his fancy 3D printers. This is the way.
