ronmcdon's daily driver Fiesta ST and occasional track build
ronmcdon
Hi got this car back in Oct 2020 during the pandemic with around 3k miles on the odometer. Always wanted to get a fun, lightweight hatchback after owning a 89 crx si and 95 civic hatchback years prior. Figure it would make a great daily driver and wanted to keep it relatively stock with wheels, summer tires and an upgraded koyo radiator but things got out of hand. I had and still have an evo x at the time that I wanted to keep for track events, but got distracted back and forth modding the two cars.
I quickly found the fiesta was a great platform to do track events, as not dissimilar to my old NA miata, the consumables were much more affordable. The car rotated just as well as my evo and the aftermarket parts were reasonable affordable compared to other platforms. First round of mods included Wavetac diff, Miester R coilovers, braces, suspension and the majority of cooling mods.
I kept the power levels stock-ish with Cobb acessport and included tunes with CA 91 octance. I did around a dozen track events from late 2020 to early 2022. Irresponsibly I ran some back to back 20 min hpde sessions in 90f tempts at track like Chuckwalla, Buttonwillow and Streets of Willow and the car held well until it did not. At some point did a more minor second round of mods after damaging the stock turbo and replacing it with another. I'm proud in succeeding in melting parts of the OEM downpipe Paused going to events due to life circumstances.
In 2023 for no good reason at all, got a 19 Honda civic si which I have had no self restraint in modding and continued modding my evo x. My Fiesta worked great as a daily driver and got no real attention.
Back in early 2025 after getting the car to 26k miles, the reverse gear went out. Originally I only planned to get the transmission worked on by Colby Clarke, but then again got distracted and began a 3rd round of modifications with a bunch of stuff not related to the transmission at all. Not being really happy with the oem recaros, I went with JDM Recaro SR-7 reclinable seats. I got an S280 thankfully before the price spiked, got Hella Euro headlights. Suspension wise upgraded to DNA adjustable front arms and Spoon rigid collars (loved these on my other cars). Threw on a Coolerworx shifter and regret badly it wasn't one of the first mods I did.
Modifications wise, I am close to being done. I'm still conflicted with whether or not to throw on wider wheels and fender flares that I already own. If I do go that route, I won't do so until earlier next year. I don't have any tires yet, but would get a more stretched fitment with a set of Continental Extreme Contact Force in 225/40/17 with a height of 24.1" which should give me good enough height clearance, especially since I think I may have had less clearance using 225/16 Dunlop Z3's that are no longer made and I cannot look up the specs.
Here's the current mod list.
Next step is the get the car aligned and corner balanced at West End alignment. Pics to come soon. Just wanted to start somewhere.
Alignment specs
+3.75 caster
-3.0 front camber, 0 toe
-2.25 rear camber, 1/16 toe out (cannot get 0 toe)
alignment done by West End Alignment, Huntington Beach, CA.
Cooling
- pro alloy radiator
- pro alloy oil cooler, non thermostatic
- whoosh coolant hoses
- motorcraft 180 thermostat
- cpe intercooler
- whoosh hot pipe and cold pipe kits for fmic
- whoosh radiator hoses
Chassis and suspension
- meister r gt1 coilovers with 8k front 6k rear rates (don't see these on Meister R website anymore).
- vibra technic 'fast street' rear motor, passenger and transmission mounts.
- 'alex the machinist' aluminum steering rack bushing
- spoon rigid collars (improved ride quality spectacularly)
- pierce motorsports upper strut bar
- tb performance crossmember brace, I brace, trunk brace, torque gusset traction bar, torsion bar brace
- powerflex 'race' front control arm bushings on oem control arms (removed)
- DNA racing adjustable front control arms with spherical bushings.
- DNA racing rear axle uniball kit / spherical bushing (rear trailing arm bushings?)
- DNA racing rear negative camber plates
- Swave Summit front swaybar endlinks
- ARP 3.25" extended wheel studs
- Enkei rpf-1 16x8 +38 bronze finish (14.9 lbs)
- Advan AD09 205/45. 200tw tires. (18 lbs)
Brakes
- Stoptech slotted rotors front and rear
- EBC front orange pads and rear yellow pads (removed, note melted on track)
- Hawk DTC 30 front and rear pads Z(removed, great on track, responsive, little modulation, harsh on streets)
- Gloc R8 pads front and rear (current)
- Endless RF 650 brake fluid
- Goodridge SS brake lines
- Boomba front brake deflectors
Drivetrain
-Cobb accessport
-ST 200 airbox with ITG panel air filter with (removed)
-Ford oem evap harness to convert 2016+ to 2014-2015 spec
-Cobb carbon intake w/ cone filter, crossover pipe, induction hose
-Cobb catted downpipe
-Thermal R&D whoosh spec catback exhaust
-whoosh crossover pipe (removed)
-whoosh induction hose (removed)
-s280 turbo tuned via TunePlus @ 265whp & 271wtq, 91 oct fuel, SAE dynojet. Dyno'ed at FSWERKS in Anaheim, CA.
-Pro Alloy oil pan baffle
-Radium oil catch can
-Turbosmart Kompact Shortie Plumb Back BOV
-Colby Clarke rebuilt transmission using new oem core
(oem transmission had reverse gear damage at 26k miles)
-Syncrotech carbon syncros assembled by Colby Clarke
-full wpc treated gears
-Xclutch with single mass flywheel (removed)
-ST200 clutch with oem flywheel (current)
-Amsoil synthetic DTC fluid.
-Wavetrac differential
-FK WERKS shifter bushings (removed)
-Coolerworx shifter
Miscellaneous
-Hella euro headlights w/ halogen bulbs
-Diode dynamics fog lights
-Antigravity ATX30-RS re-start battery (5.75 lbs)
-drivers side Recaro SR-7 KK100 black kamui reclining seat
-Recaro slider rec-0-70-9NT
-Planted seat bracket, SB 146 DR
-ARP extended wheel studs 3.25 inch
-Kicks r40 neochrome lug nuts
-Verus Engineering louver kit w/ rain guards (hood vents)
-Verus Engineering canards (bolted on)
To be installed
- passenger side Recaro SR-7 KK100 black kamui reclining seat
- Jd Titanium burnt Ti shift knob (to coolerworx shifter)
- M2 fender flares
- Braid forged 7 wheels, 17x9 +35 (approx 19.1 lbs)
rallytaff
Great choice for the BRAIDS! They can take a lot of punishment! Enjoy them!
ronmcdon
ronmcdon
throwing on the wheels are going to a real pain. Not a lot of people have gone the route of 17x9's. So maybe lot of trail and error. Consumables will def go up and it's well over a grand for a set of 4 conti Extreme contact in 225/40/17. Wish I could fit 245/40s there but that would be pushing my luck.
here's a photo of the Braid wheel i've had sitting in my garage the last 3-4 years
Given that the Conti ECS in that size is very narrow in tread width, it could help you avoid rubbing when lowered, even with the 9" wheel width, and that low numerical offset needed to clear the front suspension bits on the inside.
ronmcdon
ronmcdon
I’m most worried about inside clearance with the suspension bits. In truth, I was hoping to run 245/40/17, same tire, but height is riskier at 24.8”. The car would visually look great with that fat a tire at any angle.
think my SUV like ride height should negate height clearance with fender flares. Can fit 2 fingers between top of tire and bottom of fenders, front and rear. Right now the tighest clearance is from the inside
BTW - brought car to get alignment and corner balancing yesterday.
Alignment wise front camber set at -3.0. Front toe at 0. Rear at -2.25 with the DNA rear camber plate thingies. Interestingly we were not able to get rear toe at 0 and got 1/16 toe OUT. this might make for maybe a tad faster rotation. Caster I believe was +3.75
The DNA adjustable camber arms were a real hassle to adjust and so the whole ordeal was closer to 3 and a half hours and $500. But its a very solid race alignment shop I trust, West End Alignment in Huntington Beach CA.
How well do the AD09s work on the track, or have you not used them on the track yet?
You are one of the few who use them on here, besides me, and I do not open track the car at all.
I definitely cannot reach their limits on the street, not without compromising my freedom, at least.
Interesting. Seems like you’re in the camp of my old car now with a few extra goodies . i was wondering what you were up too.
Alignment wise front camber set at -3.0. Front toe at 0. Rear at -2.25 with the DNA rear camber plate thingies. Interestingly we were not able to get rear toe at 0 and got 1/16 toe OUT. this might make for maybe a tad faster rotation. Caster I believe was +2.5.
When are you putting on the M2 flares, once you cut the fenders you'll have plenty of clearance depending on the offset
ronmcdon
ronmcdon
I have not used the AD09s on the track and itching to do so! Hopefully with the temps coming down in CA by Nov-ish I’ll head out to do an event later in the year. Car is once again ready for track duty! I am hoping the AD09's dont get too greasy, as its my understanding they are more enduro 200's.
I thought you had the super sticky A052’s?
ronmcdon
ronmcdon
Oh you mean the s280 camp? I was definitely missing out. S280 feels like a much better fit to than the stock turbo. traction control can struggle a tad in the later rpms, but around town there is less torque steer. Car feels much more refined and at times touring car esque in the power delivery.
I am super happy with the 3rd round of mods I've done. Car feels very much transformed between the Colby trans, Coolerworx shifter, S280, Recaro seats (compared to garbage non Recaro oem seats) and DNA arms. Even the G Loc R8 pads are so much easier to live with than the Hawk dtc-30s with pleasantly violent bite but zero modulation.
I've been distracted modding a few other cars. Interestingly also building trans and throwing in a big turbo in my 19 Si later in the year. Been traveling a bit more with partner in past couple years, so harder to hit the track.
ronmcdon
ronmcdon
Not anytime soon. Maybe sometime next year. Right now really want to drive the car at the track and see how it feels. Money is a bit tight right now for me.
also have to get my Civic si transmission built. I purchased a '20 civic si trans from someone out of state almost over a year ago and don't want to impose the seller holding on the part much longer. Installing PPF 1-4th gearset https://www.ppgearbox.com/product-page/honda-l-series-1st-4th-synchro-set
Going with the 17x9 +35 Braid wheels, I am going to gain a not inconsiderable 4-ish lbs a corner but will allow me to get better front brakes. Rpf1 wheels dont have good clearance. Probably the best thing about the Braids will be that they are indestructible, or so I speculate with fingers crossed, in the Streets of LA, or worse Streets of Willow Springs.
Speaking of the bronze rpf1s, the paint is really not the best quality and seems to be chipping around the spokes. If I had to get them again, would at least get them ceramic coated.
I had (still have for sale) a set of 225/45-16 A052s I was going to put on a set of Dekagrams, but never did (they still have the stickers on them!).
I was fearful of rubbing in multiple spots on the wheel wells/suspension, even at factory ride height with those stickies, so I never even tried.
I think that the AD09s (215/40-17 on 17x8 KE Motorsport Pro T12s, the same wheels that Woods 247 has on his track monster currently) are much better suited for daily summer street use on the east coast than the A052s, yes, given their 'endurance' designation, and deeper circumferential rain grooves.
But the A052s are a much faster (at least for a short session), albeit shorter life, open track tire.
ronmcdon
ronmcdon
Thread Starter #14
I haven't noticed any paint chipping on my Enkeis, maybe it was a batch issue?
Yeah nothing terrible but I do get some chips here and there. I did maybe a dozen or so track days back in ‘21 and afaik rock chips can sometimes be worse on track events. my front end paint and chipping not in the besr condition. In retrospect should have gotten the wheels ceramic coated as well but not sure if that would have made a lot of diffference
ronmcdon
ronmcdon
Thread Starter #15
yes I did have a wee bit of rubbing when I threw on my rpf1s and dunlop z1s. I think having softer oem springs contributed to more rubbing, iirc. It was still very slight and seemed apparent when cornering down declines in elevation, as I live close to some canyons in Los Angeles.
those KE wheels seem like a solid choice. weight is very reasonable!
btw got to try sitting in the newer recaro sr-s seat yesterday as I was visiting asm yokohama recaro dealer. those things are beefier than my SR-7s. Got one for my civic and fingers crossed can check it in american airlines Hope to change your mind about recaros.
rallytaff
To save some time going to Huntinghton Beach, try Andy's Alignment on Palmer in Glendale. He can just look at your car and tell you if you need alignment or not. That's how good his eye is! I never go anywhere else!
Yes, Recaros definitely look like (or at least seem to be) very solid aftermarket seats, I just do not trust them after my experience with their circa 2004 Speed recliner.
An $850.00+ seat (in 2004 coin!) should NOT fall apart in less than two years time, especially when being compulsively careful about not crushing/rubbing the bolsters on ingress and egress of the car.
IF it does, they should either warranty it (they refused to do so), or at least sell me the covers and cushions for me to repair it (also refused to do this).
ronmcdon
ronmcdon
Thread Starter #18
Ah that's good to know if there's someone more local to touch things up here and there. I do use Darrin @ West End Alignment for a lot of suspension and alignment work. Will have him work on my Si and evo more next year.
ronmcdon
ronmcdon
Thread Starter #19
I know what you mean. I've had mixed results with them. The fabric on my oem recaros on my evo x are not doing great with age. car has barely 10k miles on them, but car has not been garaged most of life.
I do wonder if garaging the car or throwing on heavier tints help with UV deterioration. For insurance I got some ebay covers, but they definitely don't fit the best. The left side bottom seat bolster wrap always comes loose.
Seeing the new SR-S line, there does seem to be a notable improvement in quality with surprisingly compared to my SR-7s and even a decrease in price. buying parts in Japan is a lot cheaper but where you end up getting reamed is through shipping. I don't even want to think how tariffs will impact things.
Will see how well my SR-S with fake leather and acalantra holds in time, if I can get it over via American Airlines check in on my flight, or plan B going through American Airlines cargo. Have my fingers crossed this Sunday and hope I won't lose a seat I paid over a grand for. The boxes the new seats are in, are also gargantum compared to the last gen SR-7's. They would look great even in say a g80 m3 over the stock non carbon buckets.
Just an update, got the seat back to the US no issues. Box looks a bit more banged up after the flight. Did not get heckled by US customs agents so was very lucky. American Airlines just checked by box like it was regular check in luggage.
I was anticipating getting charged more for oversize luggage OR worst case scenario having to change use American Airlines cargo but that fortunately was not so.
