Transmission/clutch problems
So I’ve been experiencing some problems with my clutch as of recently, about 2 months ago I got the “SpongeBob” stage 3 clutch from whoosh and installed it along with a new slave cylinder, install went according to plan drove fine for about a month, seal on the end of fluid line is there”I know people like to say it causes slow leaks” I started to notice stickiness in my clutch. Not fully to the floor, just a delay when quickly depressing the clutch, makes a creaking/groaning noise upon fast release but is fine when slowly depressed. Figured it was master cylinder, replaced, bled, did not fix the issue, was curious if pressure plate or something with my clutch assembly could have gone wrong from the bad slave over time, when hood is popped noise seems to come from the bell housing. Open to anything please help me out🙏🏼
XR650R
I'm clueless, but maybe someone isn't.
Clutch Master Cyl? Or Brake master Cyl? Huge difference!
Sounds like a leak. Mine did that when my clutch master cylinder was leaky. It also did that when my clutch line was leaking due to a missing gasket. I'd check up on everything again I've been running the whoosh stage 3 SMF kit for 2k miles now no issues
