Bilstein Science Experiment
BC, Canada
Not strictly on subject, but since we're on the topic of B14 I had a pretty surprising experience with them today when I went out to the first autocross with the car since I installed them.
For the first run, I set the pressures to my usual F40/R40 PSI and almost spun out in the first sweeper. Compared to stock, the rear was Loose with capital L. The reason why I say it was surprising is both setups have similar front/rear spring rate ratio of about 1.2 but the difference in balance was massive. Over the day I ended up with F40/R30 PSI which made the car manageable but still notably more tail happy than stock even when tires were up to temp.
What gives?
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #162
Something isn't right. The Bilstein spring setup is basically the same as OEM balance wise, just stiffer. Now the B14 damper has a LOT less rebound than the OEM dampers and even the B6/68, so its possible that lack of low speed control allowed the car to rotate better. I kinda doubt it though as that would mean Bilstein is liable every time some clown goes off backwards into the ditch.
BC, Canada
Oddly enough, here are the pressures for UK(or Euro?) Fiestas: https://www.fiestastoc.com/threads/tyre-pressures.327870/>
For V<190km/h 1-3 persons, 36F/26R which, if we add 4 PSI, is bang on where I ended up with my pressures. I wonder if NA cars have different suspension tuning and B14s were made to match UK specs. Or is it because they are 2 doors short? Surely a door doesn't weigh that much more than the equivalent body section?
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #164
Since I put the stock rear dampers back on my car with the 1in rear roll bar, when I switched to my "winter tires" I had to drop the rear pressures way down, probably into the low 30s, high 20s. Of course I don't run my normal tires at the OEM pressures. Ride quality is much better LOL.
Have to wonder if the US engineers just put the max pressure for the potential load cases to avoid having the customer make the decision themselves. Theoretically, you should adjust your tire pressures to suit your conditions. Chalking the tires can be helpful to determine proper tire contact patch and loading.
AndyST13
UK
UK ST180 owner here. Before doing my first track day I was trying to find rough tyre pressures for circuit driving and found an EBC promotional video where a UK touring car driver was testing out an ST180 at Castle Combe circuit on PS4 tyres and they were aiming for 32F 30R hot.
I've aimed for the same using Goodyear Eagle F1 tyres on both of my track days so far, driving a mostly stock ST180 with B14 PSS suspension at Brands Hatch the car has been completely planted (regardless of ESC mode.)
I haven't tried any significant tyre pressure changes but 40psi seems like quite a difference!
Here's the EBC video. In the description they mention PS4 tyres and they replied to a comment regarding tyre pressures:
My car at Brands Hatch with roughly the same tyre pressure:
We here stateside are not allowed to have any Eagle F1s or PS4, let alone PSS tires in any sizes we could possibly use by either Goodyear or Michelin.
But then the same could be said for most tire companies selling product here (even if they sell our sizes in the UK/Europe/rest of world!:mad:) which only cater to the HUGE hoop sizes of more high $$$$ 'high end' rides and of course the ubiquitous and 'go-to' road tank SUVs and oversized trucks for the very vast majority of our motoring populace. [thumbdown]
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #168
OPened up a B6/B8 front strut for science. Nothing useful. Can't even retrofit the parts to make the custom inserts I use fit in that off the shelf housing. So I guess I will just continue to build my own housings.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #170
I don't, David picked them up to put them on his car. Those shitty Eibachs exploded and he needed something ASAP. 90% certain you don't want them for a track or autox car.
Dialcaliper
San Francisco Bay Area
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #172
Yeah, it appears these front struts for out cars are a twin tube. Its odd though, I put B8s and Swifts a Focus ST a month ago and they were a nice inverted strut that you could totally rebuild, modify the housing, etc. I have some E36 M3 struts here in the shop that I revalved for race use and they were a proper insert strut housing. Not sure I understand why Bilstein decided to go down this path with the Fiesta parts.
Does anyone make a direct fit, monotube, 'motorsport' diameter (or not) SRUT for our application, 'proper valving' or not??
I know that the old R1 (now Rally 5) Bilsteins were that (but coil overs in front), and could be had in either gravel or tarmac valving and travel specs, but those are most likely long gone, and they were over $3K (for non-adjustable dampers) when they were available.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #174
I am the only one to my knowledge, that has made something like this. I have thought about trying to offer it as a product, but I doubt people will be that interested in that when you can buy BC/Meister/Whoosh/etc chineseium garbage for a lot less money.
