Switched Power in Map Light Housing?
XanRules
Portland
Howdy.
Due to a nasty rock chip and some resulting de-lamination, I'm planning on getting my windshield replaced soon. I figured this might be the right time to install an auto-dimming mirror. The one I yanked out of the junkyard has two wires - switched 12v and ground.
Is there any reason I cannot tap into a switched 12v and ground wire within the map light housing? I also have a sunroof, so I assume there's a switched wire in there since the sunroof only works when the car is on. This feels easier and cleaner to me than trying to run add-a-circuits.
If this is doable, can anyone tell me which wire/pin is which that I could tap into? If this is not doable, can someone kindly let me know which fuse in the interior I'd need to tap into for switched power? Hopefully I don't already have something running off that circuit.
Thanks!
XanRules
XanRules
Portland
Thread Starter #2
No? Anyone got a pin diagram I can dig through?
There's like a ten minute delay before power is cut to the dome lights. Your mirror might remain on after you walk away.
(like my accessories here - https://www.fiestastforum.com/threads/guide-amp-remote-turn-on-relay-12v-outlets.29095/)
That can call attention to your car at night and when you don't want it.
If you have a sunroof, it may be better to tap into that circuit since its power requirements are much higher and seems to be cut with the ignition (no delay).
Just make sure the power requirements for the mirror won't overload the circuit's wiring or place it too close to the fuse's capacity. Don't imagine it would though. But as is said, measure twice, cut once.
XanRules
XanRules
Portland
I am laughing at myself because I asked for a wiring diagram, got one, and have absolutely no idea how to read it. I'm assuming the black/blue wire, wherever, that is, is ground, and then anything coming off the switch itself is going to be switched 12v?
Agreed on using the sunroof power rather than map light, though I'm only doing auto-dimming rather than auto dimming with compass and temperature. Also agreed on the add-a-circuits, upon further inspection the boost gauge is tapped into the vehicle wiring and the dash cam is hard-wired without the use of an add-a-circuit using the included hard-wiring kit - that said, I do recall someone saying that there was an empty fuse slot in his interior fuse box labeled "auto-dimming mirror," I just don't want to run all those wires down the a-pillar if I don't have do. Feels neater, tidier, and more "factory" to tap into the map light housing.
It seems you know how to read it after all.
Grey/Yellow (positive) and Black/Blue (ground).
Violet/White feds power to the switch. The other wires are switched. But being post-module, there's a possibility that the power on those wires may be limited.
BTW, let me know what power mirror you select, how the installation experience goes, how well it works, and all that goes and all that jazz.
My windshield was chipped literally two weeks from buying the car new. Had just merged the highway behind another car and a truck passed us up in the middle lane; shot a bullet (rock) off its back tire and that was that. It began to spread not long after. Just haven't bothered to replace in part because I figure the minute I repair it, it'll happen again LoL...
The other part of it is just don't trust anyone to touch my car LoL. (too many bad experiences) For a while I was considering removing/installing myself.
This looks promising...
XanRules
XanRules
Portland
Cool, so basically, splice the switched power from the mirror into grey/yellow and the ground into black/blue and see if it works?
And yeah, I had to get my headliner replaced twice in the first hundred miles and the windshield began to de-laminate soon after thanks to the monkeys at the dealership, I just ignored it until recently when I also got a really nasty rock chip right on the delaminated part and now it's starting to spread and look ugly. I feel you.
Re mirrors, in searching for an auto-dimming one I found a shop online called "Bob's Automotive Mirrors and More" and was incredibly impressed with their customer service, so this is the one I'm going to be getting:
https://www.bobsmirrors.com/NEW-Gen...t-Fits-Most-Vehicles-ADVGENFL8EXP_p_1604.html
It's just auto-dimming with two wires. I don't care about a compass as I have a very good sense of direction (one of the only things I was good at when I was a boy scout), I don't care about outside temperature as that's displayed on both the head unit and the instrument panel, and I don't care about homelink because I don't have a garage. Gentex is the OEM manufacturer for pretty much every rear view mirror on earth, which is why one member on here was able to wire one from a Nissan Maxima into his car with no issues.
I have heard good things about the Wolfbox units, but they are overkill for my purposes (I'm in the process of wiring up a reverse camera using the stock wiring and already have a hard-wired dash cam) and I don't think the way they "clip" onto the mirror looks nice, as someone who likes things to be as tidy and "stock"-looking as possible.
That's what I was trying to determine; whether it was clip-on or full mount. Since it had the camera on the rear was kind of assuming it was independently mounted. When or if the time comes for windshield replacement, will be searching out one that is independently mounted.
XanRules
XanRules
Portland
Well, I got lucky at the junkyard today and grabbed the auto-dimming mirror and the wiring pigtail out of a Fiesta Titanium for five whole dollars. It's got three wires - blue, green, and black - and they don't tap into any circuit up by the map light that I can see. You wouldn't happen to have a diagram of which of those wires is which, would ya? ;)
XanRules
XanRules
Portland
Okay, well, I finally got this installed PHYSICALLY with my new windshield, but my overhead console/sunroof switch does NOT have a green/yellow wire (+12v ignition) NOR a black/blue wire (ground)
Am I looking at the right switch @Intuit ?
Some mirrors offer dash recording and security feature that require hot-at-all-times power.
Might be a few out there that want power at all times in order to maintain settings in memory.
Otherwise hot in start/run is fine.
The wires to the switch could be low power. If the wires are tiny gauge, then it's a safe bet there isn't much current coming from that module and will need to tap the 7.5A or 20A power source for the module instead of the switch's power.
Roof opening panel module is located in C5 region...
If a backup cam is used...
XanRules
Portland
Thread Starter #14
backup camera is wired into the factory harness. No dash cam. This is just an OEM mirror with three wires (C911 in your diagram): 12v ignition, ground, and (optional) 12v reverse, the latter being so that it won't dim when you're backing up but I don't care about that since I have the backup camera.
It appears that I am looking for a green-yellow wire somewhere around the sunroof switch (in the "roof opening module," specifically) for +12v ignition and a black-blue wire for ground, but that may be deeper into the headliner than I am willing to dig.
XanRules
Portland
Thread Starter #16
Ah... well, this is all it has on that....
Right, sorry, I'm just trying to figure out where those get plugged in on the other end. Like, that's the connector I have, I'm just trying to find the easiest place to splice those wires in on the other side without using an add-a-fuse or whatever.
Don't think any of ours came with auto-dimming mirrors or was it only with the Recaro package?
To keep from altering stock wiring in vehicles I'll often locate a matching harness and just put together a middle-harness.
For example...
https://www.r6-forum.com/posts/5791768/
Google Lens can sometimes be helpful for locating a matching harness.
XanRules
Portland
Thread Starter #18
For example...
Nope. The US model ST is the only trim level that didn't have it as an option or as standard equipment. It was available on the ST in all other countries, as well as on the Titanium and other higher trim levels of all other models of Fiesta. I got this out of a junkyard Fiesta Titanium and snipped the wiring harness going into the headliner out.
In theory there's already a plug up there for it somewhere and I could just make the middle harness to plug it in there, but learning what I have about how Ford wired this car I wouldn't be surprised if there wasn't. I'd probably have to yank the entire headliner out to see, which I don't really want to do. Maybe next time there's a Titanium at the junkyard I can run over there and see what's up in the headliner.
Barring that, I may just run the wires down the headliner/pillars and into the body wiring harness somewhere else since ground, +12V ign, and +12V reverse should not, theoretically, be that hard to find. I was just hoping that somewhere up in the headliner there would be those wires easy to access, but it doesn't appear that Ford wants to include that information in the wiring diagrams.
EDIT: oh, duh. There it is. Right there in your diagram in Posts 5 and 13. Mirror (C911) plugs into the Roof Opening Panel Module (C921) which is between the switch and the sunroof, and that has both +12V ign and ground, though no +12v reverse (which is whatever). I'll see if that is easy to locate with the map light assembly out. If not I will think about how committed to his bit I am.
EDIT 2: okay, in the whole headliner, Yellow-Green is +12V ignition, Black-purple is ground, and blue appears to be +12V reverse throughout the entire car. I can figure this out.
