FS SOLD - 2017 FiST - 49.8k miles, Shadow Black, (Recaros, Moonroof, Navigation, and 17" premium wheels)
Trader history for Joggle (0)
Rochester, NY
2017 FiST - 49.8k miles. Bought it new Dec. of 2017. I have enjoyed it as my daily driver ever since. Even drive it to Maine and back to see Acadia National Park (1500 miles all said and done). I had maintenance done at the deal for first few years (Ford Maintenance Plan thru 12/2024) then went to local garages. No DTC are showing. Asking $11,200
Had the following replace (date):
Rear beam bushings replace (4/4/25).
Rear pads and rotors (1/17/25)
Cabin air filter (1/17/25)
Right outer tie rod end (1/17/25)
Alignment (1/17/25)
Last filter and oil change, full synthetic at 43,691 miles (1/17/25)
Evap purge valve assembly (3/11/2024)
Brake fluid flush, new brake fluid (3/11/24)
New Battery (6/1/23)
New front pads and rotors at 25198 miles (7/16/22)
Engine air filter at 19450 miles (6/26/21)
I replaced the driver and passenger vent motors after they failed about 3 years ago.
Concerns:
Summer tires on OEM rims will need to be replaced to pass inspection.
I have a set of steel rims (16" i think) with winter tires on them but they have nearly no life left on them.
Lower trim/molding on rear drivers side has a broken connector at one end, so it dangles a little..
Scuff on the drivers front corner.
Paint starting to peel around the antenna.
Muffler is getting loud and may need to be replaced to pass state inspection.
The HVAC does blow hot and cold, but the temperature has to be set higher than you would think. ( I notice that, while reviewing my old receipts, that a CMDTC of B161:15-08 was listed. Cabin Temperature Sensor. If this doesn't as is I will order sensor(s) it could be and fix it.
I can take additional pictures of specific spots, just DM me.
I love this car and it has never left me stranded. I will miss it.
EDIT: Forgot to mention that it is completely stock and never been modified. Thanks
Spring, TX
Looks like a good deal, only a bit more than what I paid for my 2017 base with ~90k on it.
This is good to know, I've noticed it seems to run cooler than expected when on Auto. Will have to look into it
Suwanee
Can confirm that this fixed this issue on mine. It was a $4 part IIRC and is swapped in about 10 minutes from the passenger seat.
