Custom gapped NGK 6510's from whoosh motorsports
ron@whoosh
Vendor
Las Vegas
now available,
select any gap size you wish - let us take care of the pain of gapping your fragile Irridium plugs and ship them to you protective bubble wrap!
If you are custom tuned, ask you tuner for their suggested gap and use the drop down menu to select the appropriate gap.
Gapping is done with an Allstar gap tool, do it once, do it right!
https://whoosh-motorsports.myshopify.com/collections/s550-mustang/products/copy-of-ngk-iridium-ix-spark-plugs-set-of-4
First of all, THANKS for offering this product/service. [twothumb]
Next, I know that most want the one step colder plugs, but for those who do not, will you eventually offer this setup in the FACTORY stock heat range as well?
ron@whoosh
ron@whoosh
Vendor
Las Vegas
I can add that - to date I have not received one order for stock heat range. I usually have 10-20 sets of 6510's here at all times. I don't have any 6509's in stock, I was waiting for the first order to bring some in to be quite honest.
Bluedrank
Winter Park
That's really awesome. The first time I got spark plugs on my srt 4 I had to learn how to gap them and I was always worried that I did a bad job, and probably did.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
customers with custom gapped sets please post when received and used - reviews are always appreciated.
These plugs ship same day in most cases[ridinghorse]
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Do you need a tune with the 1 step colder plugs?
*edit
I just added custom gapped 6509 's (stock heat range) for stock and up to approx. 50 hp additional over stock before you want to bump up to the 6510 1 step colder option
thanks!
M-Sport should enjoy this added option[lovest]
ron@whoosh
ron@whoosh
Vendor
Las Vegas
any issue in running the colder plugs with just the bolt on/tune stuff?
probably not but I did run into a conversation on FB with Randy of Mountune.
In the SRT-4 community the cars go from running 7-9 psi at 285 bhp to well over 20 psi and over 100 bhp over stock. 1 step colder plugs is a no brainer in those applications.
For the Fiesta, if you are less than 50 bhp over stock you should be looking at the stock heat range with a gap of .025. Makes perfect sense.
Over 50 bhp from stock power levels go for the 1 step colder plugs
maestromaestro
Houston
On the NGK site they claim that 6509s "don't fit" the FiST. Their recommendation is 94769 ILZTR6A8G Laser Iridium Plug... The gaps are also different - 043" (1.1mm) for the 6509 and 031" (0.8mm) for the 94769. I am wondering where this comes from...
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #13
we offer the 6509 if wanted but the 6510 can be used on all vehicles regardless of modifications added
suggested gap .027
Sam4
West Chester, PA, USA
*edit
thanks!
This is an important post. Answer is YES, a tune is needed before a colder step, and even then, may be a negative move. Keep some OE heat range plugs around and do your own testing.....
SST
Toronto
if i am on Dizzy stage 2, with FMIC and cat back, i don't think the gain is close to 50 at all, so i shouldn't use 1 step colder plug?
