Cant lock up rears with e-brake?
Charlottesville
I was driving/hooning around in the rain last night on some empty streets when I tried to do a sliding turn with the e-brake, but it seemed like the rears didnt really lock up?
I tried to do a 180*, and again the rears would not lock... The brake seems to hold when I park.
What am i missing?
How about not driving like a lunatic?
RubenZZZ
RubenZZZ
El Monte
Thread Starter #24
It's a Fiesta... If you no wanted to boring driving experience take it on the track.
Holy engrish.... I left out words whilst looking for a gif.
Planning to hit up some auto-x action later in the year.
Raytech
Cameron, WI, USA
It does not work as an emergency brake. I tried mine on snow and it locked then let go. Then i tried an emergency stop. Barely slowed me in neutral. My pads are still within spec. Pathetic. It is barely a parking brake. It definitely is not an emergency brake.
Peterson
Paramus, NJ, USA
How old is your car? When was the last time you adjusted your parking brake?
Prior car with drum brakes had automatic adjusters inside the drum.
People would often screw-up the factory calibration by adjusting the cable at the lever when the sole problem was with the automatic adjusters.
Messing with that cable basically condemned that owner (and subsequent owners) into having to periodically fiddle with the e-brake for the life of the vehicle; even after having fixed the adjuster(s).
Lesson is, take the time to understand how the system works before messing with it.
Peterson
Paramus, NJ, USA
There’s a shop manual procedure for adjusting the parking brake. It’s not hard. Time consuming because you need to get above the exhaust and take the heat shield off.
@Peterson - Looking at the diagram that @koozy posted, that would be at the balancer. Keep in mind that for the typical system with automated adjusters, that procedure is only necessary after having replaced the cables. Otherwise those adjustment points are not to be messed with.
What I don't know is, whether or not we have automated adjustment for the parking brake system in our disc brakes. I would be surprised if we didn't. I'll have to remember to take a closer look, next time I take the wheels off.
