Someone had asked ( i think it was deiselmech?) About the points of contact the 2.5 inch charg pipes have with the engine/transmission.
Now i have re aligned and re positioned this pipe several times. And its been on the car for 60k. I have not touched it other than to take these pics today. The black foam pads are door edge seal stuff i stuck on to hopefully keep the bellhousing from wearing a hole in the tube. ( did that around start of summer, it has since worn through the foam. I do have upgraded motor mounts, but that doesnt mean the engine doesnt move. And if you look real close at the flange for mounting the BOV its got a couple of deep wear marks from hitting the trans. I cant clock it farther out because it hits the fan shroud and the electrical pack that right there for the fans.
The dent came from my charge pipe blowing loose and smacking the oil filter. Thats not a big deal as it give me a little more clearance for filter wrenches and such.
I know its greatly contested. But i feel like a 2.25 inch cold side with a bov mount located farther up ( like maybe the old symposer location?) Would help. Along with clocking the boost sensor to the top side of that pipe to keep it out of spraying water/snow/salty mush.
The dent came from my charge pipe blowing loose and smacking the oil filter. Thats not a big deal as it give me a little more clearance for filter wrenches and such. I know its greatly contested. But i feel like a 2.25 inch cold side with a bov mount located farther up ( like maybe the old symposer location?) Would help. Along with clocking the boost sensor to the top side of that pipe to keep it out of spraying water/snow/salty mush.
