FS 2016 Fiesta ST, White Platinum Tri-Coat, 83k miles (Dallas, TX)
Trader history for Wes7 (0)
Rowlett, TX, USA
I'm selling my 2016 Ford Fiesta ST with 83,216 miles. The car is in great condition with carefully chosen modifications, extensive maintenance history, and a clean Carfax. Asking $11950.
$11950 in Dallas, TX area
Full photo gallery is available here: https://portals.wetransfer.com/reviews/e016d759-3cd5-4a7c-a33d-81f9a7d9b737
VIN: 3FADP4GX8GM184009
Carfax available upon request
Contact at weshelm@gmail.com
The engine has been thoughtfully modified, and tuned with a Cobb Accessport Tuner, which is included. Upon modification of the engine, the car was initially run briefly on the Cobb Stage 2 tune, before being switched to a Dizzytuning Stage 2 map. The car has always been run with quality 93 octane fuel.
OEM Recaro seats were swapped from another Fiesta ST. The seats are in good condition, with the exception of wear on the driver’s side seat bolster. While the seats have heating elements, they are not connected. Focus Titanium adjustable headrests have been added to the front seats to replace the original, non-adjustable headrests. Updated OEM USB ports from 2017+ Fiesta ST were added in the center console to enable Carplay with the factory stereo. The metal trim around the cupholders is peeling.
The car has the normal dings, scratches, and other paint imperfections you would expect for a car of this age. The paint and body panels, to my knowledge, are all original, and the car has never been in an accident during my ownership, nor did it display any accidents on the Carfax at the time of my purchase. The car has a Drawtite Class I hitch installed for a bike rack. It has never been used to tow. The car was garaged during my ownership.
I maintained the car myself, so maintenance records will not be reflected on Carfax. Most recently, the coolant tank and upper hose were replaced and the coolant was drained and refilled, engine oil was replaced, rear brake pads and rotors were replaced, and brake fluid was flushed in preparation for sale. Both blend door actuators, which commonly fail on Fiesta STs, have been replaced recently. Full maintenance history is listed below.
The car was never tracked or autocrossed during my ownership.
Modifications
17” Fifteen52 Chicane wheels (front wheels display mild curb rash)
Advan V701 Tires
Cobb SF intake system
Whoosh Motorsports Hot-side Turbo Pipe
Whoosh V3 Intercooler, black
GFB DV+ Diverter Valve
Cobb Rear Motor Mount
NGK one-step-colder spark plugs
Mountune Triple-Pass Radiator
Cobb Accessport Tuner with Dizzytuning Stage 2 map
Mountune Short Shifter
Whoosh Symposer delete
Garage Line Throttle Pedal Spacer
Extras
All stock parts, with the exception of the stock wheels and seats, will be included if desired. They are bagged and organized.
Mountune Stainless Steel brake lines
Extra set of NGK spark plugs
Cobb filter cleaner and oil
Maintenance History
The car was maintained as follows during my ownership:
7/6/2019
~30500
Tire change - Firestone Indy 500 205/40/17
10/7/2019
34063
Oil and filter change, Castrol Edge 5w20
11/21/2019
~36500
Tire rotation
12/30/2019
38100
Coolant change, spark plug change - NGK one step colder spark plugs
2/1/2020
39911
43300
Front Brakes
10/28/2020
45594
Oil and filter change, Castrol Edge 5w20, motor craft fl400s
03/03/2021
48150
Driver side inner toe rod, rear brakes, brake flush with rbf600, alignment
7/22/2021
51500
Falken rt615k tires, alignment, new windshield
8/27/2021
53050
1/29/2022
58970
Tire rotation,
3/25/2022
60563
9/11/2022
66850
Radiator fan replaced
8/18/2022
66500
Advan v701 tires
~70000
1/23
~73000
Front brake pads and rotors, tire rotation, transmission fluid change
4/23
75400
Air filter cleaning, cabin air filter changed
6/24/2023
78058
Oil and filter change, Castrol Edge 5w20, motor craft fl400s, changed RMM to cobb
12/19/2023
83090
Oil and filter change, Castrol Edge 5w20, replaced coolant tank and upper coolant hose, coolant drain and replace with Motorcraft Yellow coolant
12/26/2023
83190
Rear brake pads and rotors, brake fluid flush (performed by Five Star Ford Dallas)
