2j Racing BC Coilovers owners
East Bay
Hey guys,
I just got my 2J spec BC Coilovers with Swift springs installed. Weird thing is that my car can't be lowered that much. Just for reference my car sitting on Swift R lowering springs/stock shocks was a 1.1F and 1.0R drop, which i thought was perfect. My Coilovers on max low is definitely slightly above that. My rear is sitting higher than the fronts.
Did anyone else have this issue?
Do I just need to wait for the Coilovers to settle?
specs of my setup:
2j spec BC Coilovers
6k front/5k rear
Swift Springa
D
East Bay
Thread Starter #2
I'm the only one with this setup huh?
TempeST
Honolulu
I have that setup as well, but I am waiting delivery of my coilovers.
LilPartyBox
NYC
You may be using the wrong lock ring. If you don't know this already... To lower this type of coil, you don't use the double stack of lock rings directly under the spring. The lower, solo lock ring that is seated on the strut body is used. You first loosen it, then grab the spring to turn the entire strut insert.
