60-100 Times
US
Since vdyno numbers are all over the place, one way to compare performance/mods is by posting these times. 4th gear only, no shifting. Post your mods, tune, and elevation. Just go to your logs and calculate the difference between these two times. Sometimes the MPH is a decimal, just round up or down to the nearest whole number.
Stock hardparts. E30 Flashtune (custom in progress)
ASL: 597
60-100: 8.72 seconds
G
US
My redline isn't bumped up so I can only hit 86mph. Everybody can hit 100mph in 4th gear. 4th gear also reduces chances of wheelspin that people experience with higher HP cars.
G
US
Why would that hide your torque curve? I always see greater peak torque in 4th gear anyway. The point in measuring 40-100 is compare the rate of acceleration.
jeffreylyon
Pittsburgh
If you've got a stock turbo, my FiST (with an X-47) has a much broader torque curve that makes > 5.5K revs useful while you should be shifting at 5.5K. A BT car doesn't even start to pull hard until 3.5K. A 3rd gear pull make way more sense. Only a monster is going to have traction issues in 3rd and most of those guys have LSDs.
G
US
None of that is relevant. This isn't about shift points based on torque, it's about measuring each cars ability to accelerate within that broad range. That's why it's a 1 gear log, we're not looking to measure how fast you can shift or when you should shift. It's also about comparing people's setups. There are a lot of questions about the different builds, it's a way to compare without skewed vdyno graphs. E30 hybrids may post similar times as BT 91 cars, but we won't know unless people post their times. Why not just post yours?
EDIT: If the issue is that nobody has 4th gear logs, then a 35-85 would be comparable I think, but including speeds that are exclusive to those who've bumped up their redlines would omit a lot of people.
jeffreylyon
Pittsburgh
There’s a reason that we do full pulls; we want to see the performance of the engine over the entire operating range. It matters that hybrid offers more up top and BTs offer much more but at the cost of lower end. The fastest way for me to get from 40 to 100 is different that the fastest way for you to.
40-100 in 4th is arbitrary because a hard pull from 4th is the wrong gear and 100 doesn’t top it out. 35-85 (or 82 or whatever) is less so because it’s the right gear for a hard pull at that speed.
G
US
Maybe 35-80 for a nice round number. Looking at the logs, it looks like I'm bumping redline at just about 85. 35mph also starts us at about 2700rpm, and 80 would put us around 6100rpm.
It seems this thread has turned into a debate.
Rather than debate, each have their own thread.
Change this thread title to:
40-100 Times (4th Gear Pull Only)
35-85 Times (3rd Gear Pull)
Each can have their cake and eat it too.
In the spirit of mutual cooperation, each provide a link to the other's thread.
The public can weigh in by responding to one thread, or both.
G
US
Thread Starter #13
Stock hardparts, E30 dizzy flashtune ASL: 597
4th Gear 60-100: 8.72 seconds
3rd Gear, 35-85: 7.9 seconds
jeffreylyon
Pittsburgh
3rd, 35-85: 6.47 on an almost-finished Dizzy E30 tune, X-47R, the rest of my mods. on my profile page. I'm rolling on at 2500 so I'm pretty sure that I could knock a couple of .1's off by rolling on earlier.
G
US
Thread Starter #16
https://www.fiestastforum.com/threads/racelogic-testing-stock-vs-stage-2.9197/#post-187123
More info on what I did. Third gear pull 40-80 racelogic
87 stock 6.5
93 stage 1 intake ma performance 6.5
93 stage 2 map intercooler added 6.3
E30 6 flat
X37 E30 5 seconds.
Want to test the 2867 gen 2 aux TBD
40-80 3rd gear logs with 65* weather and 597' ASL
I did 3x 3rd gear pulls on an E30 revision everything stock except step colder spark plugs. I take the logs running in both directions because it's not perfectly flat.
Run 1: 5.5 seconds
Run 2: 5.6
Run 3: 5.6
I've estimated my car at about 199whp 272wtq with the dynojet 1.09 correction factor and smoothing of 6. I think dynojet reads very high, but everybody insists I use it to compare to everybody else's.
