Ok lots of stuff misinformation flying in this thread. There is nothing wrong with Standard 91 pump . I run a tuned s280 on it that puts out 284whp and 284 wtq those are not shabby numbers and I seriously doubt my timing is pulled back. I am not sure if it’s your tuner or something is not right if you are getting knock.
If anything it sounds like your tuner advances the shit out of your timing to begin with. That or you are getting shit gas from a station that has water condensation in the tanks. Which means they are not getting a lot of business or pumping the gas out to customers all the time or both.
I will add most pump 91 actually has up to 10% ethanol in it as refiners know its way to stretch the refine quantity. In fact they will quite often put small stickers on the pumps saying that has 10% ethanol. You do not need to worry about being tuned for that either.
Your 91 tune will function just fine in fact a lot of the local guys here have thrown a gallon of e85 in on a full tank with their pump gas tunes so the engines will run cooler in the canyons on warm 90+ days again it’s not enough to warrant being tuned for it.
Plus it burns a little cleaner as well. So ya you can run a S280 with pump 91 and have be fast as hell. You should get a E30 specific tune to run E30 though .My S280 with E30 just gets stupid and pushes 300whp and 340wtq with a base tune for E30. It’s almost too crazy for street use unless you live in the land of nothing but long straightaways.
