91 or 93 afr not really dropping past 12.7 on a pull.
PunkST
Menasha
As you all know ive been having performance and reliability issues. And im thinking i may have finally found a culprit for one of them. And it could also explain why my gas milage has gone to shit. Looking like maybe my front o2 is taking a dump on me. I still have to set up my AP to log it. But im planning to order a front o2 this weekend and get it in the car ASAP.
Ford ST
Pleasant Garden
The way to know if an O2 sensor is going bad is by watching the voltage on it, and you're looking for switching a constant fast up and down movement. If the upstream O2 sensor is not constantly moving up and down in voltage it's getting lazy basically dead. 0.100/0.999. And everything in between. Diagnostics is what I enjoyed most in automotive School.
Scannerdanner on YouTube is probably the best diagnostic technician on the planet. South main Auto is probably the best overall technician I've ever seen. Both great channels to check out.
PunkST
PunkST
Menasha
Ok. Is that something i can watch on the AP?
Ford ST
Pleasant Garden
I'm one of the few who has not a tune yet, so I'm not quite sure of its abilities. But if it has the ability to read live data you would just want to read the one for the oxygen sensor.
After doing a quick read I believe it can, but I believe it's under AF sensor.
A/F Sensor #1 Current (AF Sens 1 Curr.) -> Front oxygen sensor output current in milliamps (mA).
But you're looking for volts not amps.
PunkST
PunkST
Menasha
Allright. My only other guess is the HPFP not delivering enough fuel. Idk, shes been a hassle trying to get it back right.
PunkST
PunkST
Menasha
It was the fuel being gross. Added e85 and 91 and the afr looks like it should. Must have had a batch of stale.
