Anti-glare effect of interior rearview mirror
hong kong
My car is the Asian version of MK7, which should be almost the same as the European version. I don't know when it will no longer work. I open the shell of the rearview mirror, which has a 3-pin plug connection. I tested three wires without any voltage. Does it mean there is no power supply? Does anyone have maintenance experience?
akiraproject24
U.S. Marine Veteran
Pennsylvania
Was the ignition on or off when you checked? I would check which fuse goes to that accessory in the manual and then check that. Then I would smash out all the windows and force my next door neighbor to call me an ugly woman.
Ok that last sentence is a joke so don't do that part
S
hong kong
When checking, I turned on the power supply. Through the manual, I found that the rearview mirror power supply and the headlamp use the same fuse. The headlamp is normal, so the fuse is OK.
akiraproject24
U.S. Marine Veteran
Pennsylvania
Maybe shine a light at it to make a condition for it to auto dim and remeasure for voltage? Price a new mirror?
