I have had a similar problem, knocking around 2500-3000 rpm, moderate load.
Typically it usually happens like this. Driving around in light traffic, urban situation. Maybe 20-30 minutes of light throttle application and then I give the throttle a prod in say third or forth gear loaded. Engine pings, lift off the throttle straight up. Prod the throttle again same situation, engine pings, lift off again and that's it.
It use to do this about twice and then the ECU makes a adjustment and it won't ping again, even WOT 2000 rpm 6th gear.
Its did this a few times Always after driving around lightly loaded as describe above.
I have changed to a revised Tune recently and it appears Ok now but I am running Toluene and my Octane ratio is around 100 RON.
