Boost fluctuating when accelerating
Hey folks,
Ive had these issues going on for a while now on my 2016 Fiesta ST with about 95k miles on the odo.
There are two symptoms that occur. One happens constantly the other is intermittent.
Issue #1: Boost fluctuation - Easily reproducible.
  • When accelerating, the boost seems to fluctuate - it rapidly builds boost and drops and build and drops.
  • You can feel the power fluctuate when accelerating.
  • You can hear the fluctuation in the exhaust note.
  • RPM does not appear to go up and drop down abnormally indicating this is not a clutch issue (as best as I can tell).
  1. Here is a short video I took. You may need headphones to hear it. Listen to the exhaust note: https://www.youtube.com/shorts/W4jQtlsjKH8
  2. Here is a data log: https://docs.google.com/spreadsheets/d/1sMXSXC-MSKZU4tGidZLPa24naQkEIDHgjjzlxMrH440/edit?usp=sharing
Issue #2: Loss of power, no boost, turbo flutters. - Intermittent, difficult to reproduce.
  • Has happened randomly after driving anywhere from 10 mins to 10 hours
  • No power, cannot accelerate. No boost
  • After letting off of WOT, turbo flutters
  • Stopping and turning off the car for a moment makes it go away
  1. Short video showing the issue. Might need headphones: https://www.youtube.com/shorts/YmT4ANEzxvM
I appreciate any advice. Thanks!
Does the boost fluctuation occur on WOT? My car seems to do that weird fluctuation when I'm half-throttle, but acts normal on WOT. I can only really hear the fluctuation in the boost itself & see minor fluctuation in the boost pressure.
I can't relate on the second issue, so I apologize.
My money is on a failing throttle body that still hasnt pooped the bed yet.
I was about to make a thread but my symptoms are very similar in my Transit Connect 1.6l ecoboost. Been running forscan, no codes coming up, but basically...
>2000-3000rpm, noticible stuttering in power
>religious oil changes at 5k km
>transmission fluid changed
>air filter changed
>spark plugs changed
>fluids checked
attached are some forscan readings
