Boost gauge install
Zanesville
Hey guys I’m brand new to turbo cars and after having my fiST I knew that I needed a boost gauge so I bought a gauge and the ATI vent pod and began wired it up with help from the posts on here (thanks guys) and then began plumbing my line I went through the fender to plumb it and I had a buddy help who told me where to t my vacuum line in and all I have right now is a vacuum gauge it won’t read boost it gets to 0 and won’t go further I will attach a picture of where we teed the line in at any help would be great thanks!!
Winter Park
There is probably a check valve in that line and you might be on the wrong side of it. I have not added one to mine so I wouldn't know specifics, but have installed them before on other cars
Looker44
Zanesville
That’s where it’s plumbed in at
Looker44
Zanesville
That’s kinda what I was thinking after doing some research but I wasn’t 100%
Looker44
Zanesville
Yes that’s kinda what it looks like to me too now to figure out a way to move it to see if that does anything at all
Looker44
Zanesville
That’s exactly what it looks like and that’s where I wanted to put it to but that’ll be the last time I listen to him lol
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The best place to connect a boost gauge on the FiST is under the MAP sensor using a MapTap or similar.
This way none of the plastic hoses need to be cut and you can always return to 100% OEM easily.
Dave
Looker44
Zanesville
I knew of those but I figured since my buddy had installed boost gauges he knew what he was talking about [emoji1787]
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The downside of the MapTap is the cost but I still think it is the best way.
Dave
Looker44
Zanesville
Right that was a big downfall for my atm but I’m hoping if I move it to the other side of the valve it’ll work fully
XanRules
Portland
If that's the line I think it is, the line you've tapped into is before the throttle body and thus will not read vacuum, only boost. You need a MAPTap or similar device to get boost and vac.
EDIT: wait, you're only getting vacuum, not boost? Maybe that's not the line I think it is. Hm.
Looker44
Zanesville
Thread Starter #13
It’s the right line just the wrong side of the check valve it works perfect now
Looker44
Zanesville
Thread Starter #15
Yea give me about 30 mins and I will
Looker44
Zanesville
Thread Starter #18
Yea I’m sorry about keeping y’all waiting
