Chassis Swap
Colorado
That's my fake ST build!!! So things to watch out for. EVERYTHING has to swap. Motor, pcm, all wiring engine and body harnesses, you'll need the bcm for the pats to let the pcm command fuel pump on, youll need the RFA module under the passenger seat too. Even the airbag impact sensors had to be swapped. they connected but gave me a open code. Tail lights harness swap, don't forget the key fob antennas in the rear bumper and most important is the one in the headliner. Without that the car will not know it has a key in it so won't do anything. ST side skirts will not just plug in. The se or my ses do not have all the holes for the body clips. ill be drilling them out by hand soon enough. EVAP canister on ST is smaller then 11 ses on so didn't bolt up. you'll need the hood, fenders, front bumper cover and headlight for the front end to work..... at least pre ->post facelift. You'll need the fuel tank.... cause you'll need the fuel lines. I had to swap front brake lines and the middle section for the rears. Dash is impressively heavy so get a helper unless your as dumb as I am. But yes more or less everything just bolts up.
Make sure to get the entire ST suspension as the ST rear end tube is much beefier and the shocks springs are different as well.
AC accumulator bracket..... ses frame didn't have a hole for it either.
