Clutch Related Issues Poll - Fiesta ST
Ford Fiesta ST Clutch Initial Issues Poll
  • 2014 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 1 7.7%
  • 2014 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 2 15.4%
  • 2014 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 1 7.7%
  • 2014 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 0 0.0%
  • 2014 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2014 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 0 0.0%
  • 2014 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • 2015 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 2 15.4%
  • 2015 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 1 7.7%
  • 2015 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 1 7.7%
  • 2015 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 0 0.0%
  • 2015 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2015 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 0 0.0%
  • 2015 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • 2016 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 5 38.5%
  • 2016 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 2 15.4%
  • 2016 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 0 0.0%
  • 2016 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 1 7.7%
  • 2016 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2016 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 1 7.7%
  • 2016 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • 2017 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 0 0.0%
  • 2017 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 0 0.0%
  • 2017 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 0 0.0%
  • 2017 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 0 0.0%
  • 2017 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2017 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 0 0.0%
  • 2017 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • 2018 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 0 0.0%
  • 2018 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 0 0.0%
  • 2018 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 0 0.0%
  • 2018 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 0 0.0%
  • 2018 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2018 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 0 0.0%
  • 2018 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • 2019 Clutch Pedal to the Floor, sudden, intermittent, full failure.
    Votes: 1 7.7%
  • 2019 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B Factory Original Install
    Votes: 0 0.0%
  • 2019 Clutch Slave Cylinder Failure P/N DG9Z-7A564-B New OEM Replacement
    Votes: 0 0.0%
  • 2019 Clutch Master Cylinder Failure P/N CV2Z-7A543-A Factory Original Install
    Votes: 0 0.0%
  • 2019 Clutch Master Cylinder Failure P/N CV2Z-7A543-A New OEM Replacement
    Votes: 0 0.0%
  • 2019 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J Original Install
    Votes: 0 0.0%
  • 2019 Clutch Pressure Plate or Disc Assy Failure C1BZ-7B546-J OEM Replacement
    Votes: 0 0.0%
  • Vehicle Mileage was under 10,000
    Votes: 0 0.0%
  • Vehicle Mileage was under 20,000
    Votes: 2 15.4%
  • Vehicle Mileage was under 30,000
    Votes: 1 7.7%
  • Vehicle Mileage was under 40,000
    Votes: 1 7.7%
  • Vehicle Mileage was under 50,000
    Votes: 2 15.4%
  • Vehicle Mileage was under 60,000
    Votes: 2 15.4%
  • Vehicle Mileage was over 60,000
    Votes: 2 15.4%
  • Ford Repaired the Issue under Warranty
    Votes: 4 30.8%
  • Ford Denied the Issue under Warranty
    Votes: 0 0.0%
  • The issue occurred when temperatures were low to normal, below 80 deg F
    Votes: 4 30.8%
  • The issue occurred when temperatures were high, 90 deg F or above
    Votes: 4 30.8%
  • Repairs were made once
    Votes: 2 15.4%
  • Repairs had to be made more than once
    Votes: 2 15.4%
  • My vehicle experienced more than one clutch related failure
    Votes: 2 15.4%
  • This failure did not cause a traffic accident
    Votes: 7 53.8%
  • This failure DID cause a traffic accident or incident
    Votes: 0 0.0%
  • Total voters
    13
Texas
It seems to be able to get a more accurate idea of what problems exist and remain factual, it would seem to be a good idea to have a poll that lets the members post quickly, what issues they have seen on their personally owned Fiesta STs, US, Canada, UK. If you are part of another group/forum, invite others to join and report their experience here.
Additionally: If you have had a slave cylinder or clutch master cylinder failure happen, new replacement, low mileage failure or otherwise, report it here on the poll, and take time to report it at https://www.nhtsa.gov/ and https://www.carcomplaints.com/Ford/Fiesta/ also. Report Year, Mileage, Failure, general area of the country you are in, and any correlation that you might think might give clues, like right after a really couple of hot days, etc.
SFV, So.Cal.
I seems to me that this poll would be more valid if there was a place to indicate "NO PROBLEM AT ALL".
Or even "FAILURE CAUSED BY DRIVER ERROR".
Then we could see a more true percentage of our member's issues.
Just an opinion.
Decatur
Add a box "Idiotic to put the slave in the bell housing?" You can mark it "yes" to save everybody the effort.
Quisp
Davenport
My clutch failure was to dealer not installing locating dowels in replacement engine .
