CMbuildz brake cooling shrouds/ducts
Trader history for CMbuildz Racing (0)
Siestarider
Stuart
I tested a set of these, 2" air hose works great, larger hose will not fit through the suspension the easy way 2" will. My temp testing is posted somewhere in Brakes section, they dropped my front disc temp peaks at least 500 F.
Having had them on a while now, I believe they also conserve front pads. However, I am running a Quaife LSD so that also helps a lot.
More recently I changed to some WW front calipers with Carbotech XP-10 pads. I have experienced none of the brake pad or rotor issues from hard tracking others have reported. If anything I suspect I can go down in pad rating because the current setup may not be getting hot enough for optimum performance. Speaking to feel, not braking power.
