Critique my upgrade path
Atlanta
I have a bit of money to spend and want to finish upgrading my car. As far as my use case, it's my daily and I don't take it on the track. My philosophy for modding the car is OEM+, and I'm more interested in performance than aesthetics. Aside from regular enthusiastic street driving, I take her on spirited mountain runs when scheduling allows. My wife and toddler-aged daughter are sometimes in the car with me so I'd like for the ride to be a bit more compliant, and I'm not opposed to a small drop either so long as the suspension geometry remains intact. The car absolutely rips with the LSD and Dizzy tune so I want more braking power to balance it too.
This is what I have done already:
  • AP with Dizzy Stage 2 (93 octane)
  • Whoosh V1 intercooler
  • ST200 airbox
  • MFactory LSD
  • Konig Dekagrams
    • 205/45/16 Continental Extreme Contact DWS06+
  • Pedal spacer
Now, onto my planned mods:
Anything I'm missing? For those of you that have a similar OEM+ philosophy for your car, would you do anything differently? Bilstein's B14 coilover kit is a popular choice, but I don't want or need the adjustability since this is my daily, and I'd really prefer to just "set and forget" my suspension. Also, I know Whoosh offers the Wilwood Rear BBK too, but I can't justify a nearly $1k difference for only 18mm in rotor size (Wilwood rear kit is 298mm vs Pumaspeed's 280mm).
Let me know your thoughts.
Grsemky
U.S. Navy Veteran
Arizona
I wouldn't worry about brakes unless your really into tracking it... Modern brakes have more than enough force to lock up a wheel, that's why abs is a thing. Bigger brakes resist fade and manage heat better but that's it
Tires and brake pads will make the biggest difference, upgraded radiator is a no brainer!
our guile
Atlanta
Good point on the brake kits, and that would save me a ton of money...
Yes, for your useage a BBK setup is more for aesthetics than anything else.
(But I do not blame you, since they do look GREAT behind some nice wheels!)
How horrid are the roads around your parts?
If really bombed out, I would possibly forgo any FRONT, adjustable camber plates, unless you meant Ron's REAR hub camber plates?? [dunno]
I seriously talk myself out of a BBK almost every month... I do have a thread bookmarked that details taking the brembos from a Renault megane and the rotors from a svt focus...
Those Megane brakes are probably getting more scarce by the day, but a great way to put a top quality big setup on our rides. [thumb]
our guile
Atlanta
The BBKs do look good, but if they're overkill for a street car I'll spend the money on new pads, blanks, and some Endless RBF-600 fluid instead.
I'm in Atlanta, so some areas have smooth roads and others are just a step above some back country off-road trail haha
And yes I meant Ron's rear hub camber plates.
our guile
Atlanta
You don't need the brakes... just use motorcraft S pads. only downside about them is that they dust like crazy (at least for me)
Those are what I've been running since I bought the car new and they do a great job. I just figured with the added power and traction from my current mods it was time for more stopping power too. But fresh pads, rotors, and fluid should be good enough
Dialcaliper
San Francisco Bay Area
I’m going to agree with everyone else about omitting brakes. Stock are more than enough for any street car.
I made myself a promise that I would keep with the stock brakes until I legitimately experienced pad fade on the car. That lasted through 3 years of flogging the car on the street and in the hills and only changed very recently as I’ve started taking the car to the track for HDPE events, and finally legitimately got the stock brakes to fade after pushing the car pretty hard, even after trying out some basic ā€œtrackā€ pads that lasted a bit longer before giving up.
