Cylinder head porting and boomba spacers?
hey guys my cylinder head needs to be replaced and im looking to replace it to be better. Puma sells a head that's ported and boomba sells the spacers. also, deadhook offers a porting service. I was looking to do both, the porting and the spacers. anyone on here with both or either and whats your thoughts? money isn't much of an issue as it was going to be a lot to replace anyway. also will be putting a big turbo on this setup around june time. so far its cobb fmic, cobb ap, cobb rmm, injen intake right now (looking to get the 2j), and an atp catless downpipe. Thanks for the words of wisdom gentlemen.
2006ser
Why does your cylinder head need replacing?
P
frozen spark plug. Broke off inside the head.
Hijinx
Well, damn. Just go ahead and do a build with DHM. Problem solved.
Young L
well if you are going to go threw all that you should look into a set of Piper cams or Mountune cams
Quisp
Should be easy to get plug out with head removed.
