Data Logging in Heat
Currently working with Tunewerks at the moment. Just ordered the S280 kit and should arrive soon.
I live in Florida and the heat is pretty bad(97-109). Will sending in data logs in the heat negatively impact results when the turbo weather gets better?
I can ask Randy but I enjoy getting feedback from the community as well.
No, if anything it will make sure your tune is conservative enough to handle the worst conditions that you’ll need the car to handle. The last thing you want is an aggressive tune that becomes problematic once it gets hot where you are.
The ECU is pretty good at compensating for conditions. The only downside is that the power numbers that your logs show will look disappointingly low. But the most important purpose of taking the logs for your tuner is making sure the tune is safe for your engine
