Fiesta SD card
kivnul
U.S. Army Veteran
Deer Park, WA
I think Sync2 still used SD cards for navigation: the cards hold the maps. Assuming you have had navigation up to this point, you could try to take the existing card out and put it back in. Used cards are not very expensive on Ebay as well.
https://www.fiestastforum.com/threads/install-new-nav-sd-card.24837/
A thread of another Canadian with a 2014 and the same issue as you. Seems his card just started working again.
C
Toronto
Thanks for the quick reply , does everyone get a card with the car I can't find mine
kivnul
U.S. Army Veteran
Deer Park, WA
If your car came with Navigation, it would have came with the SD card already in the slot. If your SD card slot is empty and you didnt stick it inside the manual or hide it somewhere, then you will need to get a new card (with navigation files on it) it order for your Navigation to work again.
In 2016 the Fiesta ST went to Sync3 which does not use SD cards anymore.
C
Toronto
C
Toronto
Thanks again that's what I wanted to know, maybe all I have to do is reinsert it to fix my problem
