I need to monitor mine to ensure the 5" 100 cell cat is getting hot enough to work properly, I know it takes a bit longer to heat up as can smell it then once warmed up I never smell fumes so it must be doing a decent job. I knew it might be a bit to big and 100 cell might now work out but I wanted to try the highest flowing one I could find.
I do have the DP double and triple wrapped which will help quite a bit and all SS parts of course which helps as well.
If it is not doing the job I want it to do I have already been looking at modding the stock DP to flow really well but cutting out the restrictive areas and welding in sections cut from 3" tubing and then adding a 3" flex and outlet.
