Front most tranny mount bolt seized
Rocketst
So took out my tranny today and put it back in only to find my front bolt off the channel seems to have bent so much I can't get the bolt all the way down. Can I use washers? Should I drill and tap the hole bigger? Looking for creative options as I don't have a lot of time.
PunkST
Go for a similar grade 8 bolt from the hardware store and send it. That happened on my svtf lol. The bolt is continually side loaded so thats gonna happen.
R
Rocketst
Alright. Should I just drill it out slightly bigger and retap then?
PunkST
Id just find one that as exact a fit as possible. If you cant. Yes, drill and re tap. Youll also have to drill out the mount for the bigger bolt.
R
Rocketst
Alright. I wish I could just straighten the threads out. This happened to my engine mount bolt too. Luckily it was just the bolt that fucked up. I was gonna try to bend the threads back with a screwdriver but I don't know how hollow our channels are. If the threads just protrude with no support I may end up just cracking them.
R
Rocketst
Hey punk, thanks for lending your sanity. Bolts fixed, redrilled with 27/64 bit and then tapped in a 1/2 13
