SLD Gold Coast Big Brake Kits (323mm Front & 302mm Rear) Monterey, CA *PRICE DROP
Trader history for Fiestig (14)
Fiestig
Pacific Grove, CA, USA
Gold Coast Big Brake Kits (Front & Rear)
323mm Front Kit: $440 $350 $300 PLUS $20 USPS Priority Shipping
302mm Rear: $300 $240 $200 PLUS $15 USPS Priority Shipping
Cleaned all of the hardware for both front and rear. (front rotor spacers not pictured but included. They are soaking for cleaning)
Only 446 miles on front rotors. The rear were on the car when I bought it. But there is barely any wear on the rear rotors
FRONT
REAR
FRONT ALTERNATE (10mm wheel spacer not included)
Fiestig
Fiestig
Not hard. The fronts are available on Gold Coast and the rears believe are off of an rx8. I can get the part # off of the rotor edge. I looked them up previously and they are available in drilled/slotted. No matter what, the rear would need to be re-drilled for the proper pattern
Saint Pauly
How hard is it to find replacement rotors for this?
They will most likely have to come from Gold coast due to the Re-drilling for the wheel studs as they have the template*
Rocketst
Chesapeake, VA, USA
Damn that's unfortunate. Too much effort for me. Good luck with your sale man they look really nice. You did a good job cleaning em up.
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
The front rotors are from an RX-8 Mazda and the rears are from a Focus RS.
New top quality replacement rotors (front or rear) can always be ordered from Gold Coast Automotive (drilling provided) in all styles (plain, drilled, slotted, etc.).
You can also purchase rotors at your local parts store and drill them yourself using the supplied hub spacer as a templet.
TemecFist
Temecula
Those are some expensive rotors! (Not from the OP, but just in general) 😳.... $500 for rotors, brackets, and some bolts? Am I missing something?
Rocketst
Chesapeake, VA, USA
Well I mean I just bought svt rear and after dtc pads, ebc 280mm rotors and the actually brackets I'm in almost 600.
Fiestig
Fiestig
Cost is of course relative to development (well documented here: https://www.fiestastforum.com/threads/big-brake-kits-using-oem-calipers.17161/),rotor type, rotor mods, and uniqueness as well. Stopping power is much much improved. I assure you I did some good testing to see before I put the new rotors on for a road trip and I was extremely surprised. It was easy to compare test considering I have my 2017 with stock brakes that I could hop into and see the difference immediately.
Even the visual difference of the fronts kinda speaks for itself
Fiestig
Fiestig
Thread Starter #16
Sure. I can pound out a 4x108 to 4x100 in about five minutes. You’ll have to ask really nicely, though!
Just for reference 4x108 to 4x100 won't help ya in regards to this For Sale thread.
I believe these are the specs:
Front: Convert from 5x114.3 to 4x108
Rear: Convert from 5x108 to 4x108
jeffreylyon
Pittsburgh
Sure, my point is that it‘s not a big lift.
Woods247
Atl
Goldcoast Automotive is fantastic to deal with. I have the rear setup and everything fits perfectly.
