HERP-A-DERP Bilstein Coilovers VS Eibach Springs?
Thanks, but I am only going to be driving down these stage roads, while volunteering/working on/helping run the controls of ARA stage rallies, on the factory dampers, NOT 'blasting' down them at even HALF of a lower classed car, regional rally car's pace.
I AM going to get a better setup, but I am waiting on Ground Control (HURRY THE EFF UP!!) to release their linear rate spring, coil over conversion kit for these cars, to use with/OVER Koni Sport (yellow) dampers, or possibly the Bilstein B8s. [wink]
I know that many on here are STAUNCH believers in, (and use themselves) all of the Sino made 'coils' kits for our ride, but sorry, I just do NOT trust them at all, especially not on less than glass smooth roads. :(
I would go with the M-Sport/Team O'Neil, R1 Fiesta gravel spec, Bilstein 46mm, inverted, 'Motorsport' coil over damper setup, but one must use a L-O-N-G spring with those which raises the car much higher than even factory height, which I do not want save for working rallies, AND they cost > $2500.00! [crazyeye]
(They do not offer a similar, lower ride height, 'tarmac spec' setup like that, as for that scenario they expect one to go to the almost $10K Reiger, 3 way adjustable, reservoir, tarmac setup. [ohcrap] )
TERAWR
Thread Starter #22
So, I picked up those Meister R's posted a little while back, anyone out there know what the dampers are set at from the factory?
Like how many clicks hard<>soft?
I figure it'll be a good baseline.
MeisterR told me 16F/24R from full stiff was a good baseline when I first got the coilovers. It’s all up to customer preference. I’d start out there and move in the direction you feel is right.
TERAWR
Thread Starter #24
Thanks, is that from full lock soft or hard?
Found the answer in the installation manual, 0 is full hard.
