How Much Neg Camber Can You Get For AX With & Without Camber (Crash) Bolts?
As the title asks. What have you gotten with and without and what do you like for your AX setup?
Thanks!
Kazz
Thread Starter #2
Bueller?
The car comes set to ~-1.2 deg in front. You likely won't get much more but traditionally you can get another 0.2 from loosening all suspension bolts with the wheels on grease plates or alignment machine and pulling out on the bottom of the wheels.
That said I can tell you the FiST suspension bolt/hole tolerances are pretty tight. You can shift the front subframe to bias the alignment to one side or the other though.
I have camber bolts and set it to -2.4 in front.
Plainrt
Slotted my struts and run -2.5 in front
Kazz
Kazz
I like a compromise of -2 front, -1.5 rear. Sounds like I'll have to be more conservative, then, to stay in stock class. Thanks for helping set my expectations!
