The car comes set to ~-1.2 deg in front. You likely won't get much more but traditionally you can get another 0.2 from loosening all suspension bolts with the wheels on grease plates or alignment machine and pulling out on the bottom of the wheels.
That said I can tell you the FiST suspension bolt/hole tolerances are pretty tight. You can shift the front subframe to bias the alignment to one side or the other though.
I like a compromise of -2 front, -1.5 rear. Sounds like I'll have to be more conservative, then, to stay in stock class. Thanks for helping set my expectations!
