I had a goal of 350WHP to be at the same power to weight ratio of the Turbo Porsche so one could not run away from me on track, drag racing then slow in the corners is what I have seen far to much off and hard to get around them....The EFR put me in the same power to weight ratio as a C7 Vette just on 91 octane but it was pretty laggy then mid band donkey kick making it exciting but a bit dangerous at times with the torque steer so I decided to go WMI and the GT2560R with billet wheel upgrade with a goal of 350WHP if possible on 91 and WMI.
4200 ft elevation is not helping reach that goal, so far just 293 WHP and 252 ft lbs and laggy like the EFR with less torque but once it spools up it pulls quite hard, rev to 7000 or more and it drops nicely into the torque curve so nearly as quick as the EFR when driven right. Likely to sell the car soon but have considered the GTX with the smaller A/R as it seems to work better at altitude but now really looking at the C 37 or.....
The below is something I seldom would consider doing but it was a very safe place and I just had to see what it could really do so I broke one of my own rules about only playing with other cars on track.
Yesterday while in Mexico I ended up beside a current model M5, rated at 560HP, it was a DSG version, stop light on a divided highway, wide open road ahead. We looked at each other and I motioned to go for it and we did and as expected he was two car lengths ahead almost immediately though the lag helped me hook up and start pulling back up, hit second and pulled ahead, hit third, let off at around 85, 2-3 lengths ahead. I jammed on the brakes as it was a 65 zone down to the limit, he slowed and pulled up beside me and gave me a big thumbs up and smile
I looked in the mirror and low and behold, must of been well hidden, no lights, guy in the BMW dropped back behind me, officer pulled up even and did some kind of signal, came up by me and did the same, pointing at his eyes, the road, me....telling me he saw it all and take it easy then he punched it and took off, whew!
My turn off was coming up, guy in the BMW pulled up as I was slowing and gave me an even bigger thumbs up and smile and then went on down the road.
My car hooks up really well for street tires unless I intentionally do a burn out in 1st gear which I have done only once or twice in 2.5 years, second gear it barely spins, third it has chirped the tires a couple of times. Full suspension bushings, 8/7K Swift spring on BC coilovers, all engine and trans mounts done, LSD, 225 Rival S tires on 9" wide wheels with approx 8.25 tread width and super sticky. Pretty amazing acceleration when you have that kind of HP, it did the same with the EFR but pulled much harder down lower so easier to get it on with a wider power band. All the mods add up to putting the power to the ground, I have beaten hundreds of higher power to weight ratio cars over the decades because I build the whole car to use it well in all aspects, handling and brakes included.
Moral of this story, this car can be incredibly quick without massive HP if you set up the whole car to work as a package and 300WHP is more than enough for most any situation and much more than anyone really "needs" on public roads and on most road race tracks as well, drag racing is the main exception as long as the car can use it. Instead of looking at the most power one can get it is best to look at it from the most power more of the time that will do all you really need from the car for the least cost and hit on reliability then go out and have fun, on a track as I know I should only do.
This is the major reason I am likely selling the car soon, I am no longer going to track it as planned and I am not going to go hooning around in it either so this incredible little car I put together from the amazing FiST platform simply does not have a proper place in my life now. I love the car more than most I have built including far more costly cars like the C6 Vette I had a few years ago.
(It was fun to kick butt on a $95K car in my humble little FiST I have to admit
Have a great day!
Rick
Have a great day!
Rick
![Wink [wink] [wink]](/images/smilies/wink.gif)
).![Frown [:(] [:(]](/images/smilies/frown.png)
![Really Confused [???:)] [???:)]](/images/smilies/confused.gif)
