I am looking for H1 led bulb that works in OE housing.
New Jersey
I am trying to find H1 led replacement lights to fit in the OE headlight assembly. Any help would be appreciated.
XanRules
Portland
No.
One:
"I have the factory US reflector lights and want the best headlight bulbs I can get" - buy the Vosla PGJ19-2 on eBay or from Daniel Stern.
"I have the factory US reflector lights and want LEDs" - absolutely not. This cannot be done safely or legally.
"I have the Euro projectors and want the best headlight bulbs I can get" - buy the Osram 64217 Equivalent H7 from Daniel Stern.
"I have the Euro projectors and want LEDs" - buy the Osram LEDriving 64210DWNB-G2 and - if you have the OEM Euro lights - adapter 64210DA02. This adapter is not necessary on the Depo or TYC lamps. They are much more expensive than the aforementioned halogens (the Osram equivalents) and perform worse.
https://www.fiestastforum.com/threa...need-to-know-about-automotive-lighting.17409/
Two, the OE headlight is an H11, not an H1. The high beams are H1s, but LEDs are especially not suitable for high beam use, to the point that most OE manufacturers who use LED low beams still use halogen high beams. If you are looking for the best possible H1 bulb for your high beams, it's the GE/Tungsram +120. This is the best and brightest H1 bulb on the market and it's not close, it's also $19 for a pair of them on eBay: https://www.ebay.com/itm/266145024434
Protect other drivers and yourself.
Sam4
West Chester, PA, USA
Lucas (the prince of darkness) makers LED replacements that look quality. Just got a crutchfield catalog - they're a vendor. BTW, I just put H1 X130's in mine from Hella / Rock. daytime...
