Intake install - problems (update - fixed!)
I poured my heart out over in the "What did you to to your Fiesta ST today?" thread and that probably isn't the right place to ask for help. But here is a link so i don't re-post everything again.
http://www.fiestastforum.com/forum/...iesta-ST-today?p=298192&viewfull=1#post298192
From what I've gathered from my own research since this morning (and I could certainly be wrong) is that it appears this Revo intake is for 2014 - 2015 only. The somewhat obvious sign is only one place to connect a vacuum line into the induction tube. Starting in 2016, there are two connections to be made. So I can probably solve that with a 2016+ "fix". I'm not getting the evap code, but I suspect this is why I'm getting the code regarding a leak between throttle body and intake (can't recall the code#) since I think that line is under vacuum.
But the thing I can't figure out is the drain tube. When I look at all of the aftermarket pictures of intake systems, it is just a long hose with no connectors. However, the stock drain hose has a connection for what I think has something to do with the crankcase pressure. With it not connected right now, I'm getting a constant code P051D. Is this another 2016+ thing? How do 2016+ intakes handle this connection?
Here is the stock hose with connection on top.
Here is a shot of the hose for my Revo. You can't see the entire thing, but this is what it looks like. One side into the CC, the other into the underside of the intake.
Any help is appreciated. I'm contacted Ron and Revo to see if I'm just an idiot. In the meantime, will probably but the stock setup back on (which will make me cry).
