Installed over the last 10 days a custom short shifter from grey fist (the shift lever itself not transmission adapter) and new turbo.
Upon startup yesterday I got the following errors:
- 911 assist not available
- Hill start not available
- U210B - lost communication between fuel pump control module A and restraints control module
What I have done so far:
- Pulled covers off shifter tunnel and checked connections removed during shifter install. Verified all connected.
- Checked every fuse under the hood. All good.
- Checked fuse under dash for Transmission control unit. Powertrain control module. Anti-lock brake system. Stability assist. Fuse is good.
- Cleared codes and flashed an old tune that I know had no codes. No help.
- Disconnected battery overnight. No help.
Any thoughts? Had none of these codes before the installs.
