Method 15x7 ET48 (requires 20mm spacer to clear caliper front face, barrel clears without issue)
Sparco terra 15x7 et40 (no spacer required, barrel clearance ~1mm): May need to investigate this clearance further since minimum clearance should be 2.54mm.
[mention]M-Sport fan [/mention]
With the barrel thickness of the rally-inspired wheels, you cannot increase rotor size from the OEM specified 278mm, in my opinion. Clearances are just way too tight.
