Lower springs in conjunction with chassis spacers
the duke
Question;
I'd like to run new springs and dampers, but due to roads and just personal preference, I don't want to lower my car more than some .5" or so. In looking around I've found a company (In Russia. Because of course it is) that makes a slip-in polyurethane spacer essentially to raise the car some 15-30+mm (There's a multitude of ranges). Out there question, but has anyone used this type of system on their car? My Frankenplan is to run a set of springs/dampers and run a set of 15mm height spacers to recoup some of the ride height. The front slots between the strut hat and chassis, the rear is just a taller spring isolater.
I'm not crazy, I swear.
RubenZZZ
Are the spacers those rubber cube pieces that fit between coils?
Or are they lifting cups?
T
the duke
The front is just a slab spacer between the tophat and car.
The rear is just a taller isolator.
^^^THIS looks like a possibility for me, to use with some Swift Spec Rs/Bilstein B6es, IF I do not go for the M-Sport R1/Bilstein tarmac setup, which necessitates changing out the front uprights/knuckles for the base Fiesta versions (also it would be less than HALF the cost of that R1 setup). [thumb]
