Hey folks. Car is indeed 2580lbs, you read it right. Trunk materials and back seat removed (115lbs less), removed washer fluid reservoir (5lbs), OZ Ultraleggera 17x7's w/Eagle F1 Tires (36lbs less total), Tarox 6pot 300mm Two Piece BBK (10lbs less), Braille Lightweight Battery (15lbs less). Puts me at 2539 down from 2720 factory, now add back in 20 lbs for the heavier CPE intercooler and the braces on the car are another 15-20lbs total, so right around 2580. Add the 175lbs for me to the car as done in VDyno and there you go.
  If I raised the weight it would actually bloat the dyno results higher since I'd be going the same speed with more weight...
Updates on VDynos and logs below. Shooting for 290-295 end point right now at 27psi, right where I was looking to be. I went back and made sure the baro pressure was as close as possible (sea level baro for my area then adjusted for elevation at 940 feet above, using Weather Underground historical data), forgot to do that last time I posted them all (altitude correction). Weather is much colder today so that's helping a bit on the latest run.
- Red line is 11.5psi, wastegate pressure only, 0% WGDC (non-billet WGA)
- Blue line is 15.5psi
- Green line is 21.5psi
